So I made an air/oil separator. Another one of these things that turns into an all day project that shouldn't. Still need to make up a bracket and it will bolt to front of passenger side head. Just need to finish cleaning it up and painting it after making bracket. I really need to look into a TIG welder again that can do aluminum.
2ea -10an inlets and a -12an outlet. Baffled inlets to direct downwards. Airflow then passes thru a stainless perforated screen, packed coarse stainless steel wool in. Then another piece of perforated screen. Outlet will go to electric vac pump and there be a small filter on outlet of pump.
