*Make your stock Mustang a capable corner carver w/ street manners*
I have the following for parts for sale that I had purchased for my foxbody. Some parts will fit other years but that is the buyers responsibility to find out what will work for his/her vehicle. Most parts are used but in great shape unless noted!
Springs:
FRPP “C” Springs (New in Box) - $145
Struts:
2004 Cobra Bilsteins with low miles - $125
MM Caster Camber Plates (94-04 mustangs, black, MMCC9994, paint peeling some) - $125
Spindles/Steering/Chassis:
94/95 Spindles: Nice shape, cleaned/primed/painted, smooth/tight wheel brgs - $150
BAER bump steer kit, tapered stud, may need 1 nylon nut - $65
MM 4-pt k-member brace with hardware (79-93, MMKB4-1) - $60
Solid Alum rack bushings for stock k-member (not offset)- $25
Brakes:
Real Carbon Fiber Brake Ducts for 94-04 spindles (MTC is manuf.) - $125
13” 2001 Cobra calipers and brackets, loaded with 50% semi metallic pads, Russell braided stainless hoses, two rubber piston boots are torn but still perfectly functional - $175
Rear Suspension:
Maximum Motorsports Heavy Lower Control Arms (MMRLCA-1
like new) - $175
OEM Ford Upper Control Arms with new OEM diff bushings (Everything new, fits 79-04 cars) - $125
Kenny Brown Panhard Bar c/w hardware and paperwork - $200
Cooling:
FRPP Alum Radiator for foxbody, 2 row with c/w electric fan and hoses - $175
Rear Axle:
OEM 28 spline trac loc unit from 99 cobra, low miles - $70
