Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: your opinions on engine (stroker) plans....
  1. #21
    Petersburg,PA. 16669
    816
    I am curious as to why everyone likes the Holley intake ? I'd really like to understand this as I've never used one and don't see a reason too but I'm curious
    88 GT...and some boost
  2. #22
    they just work , they make great torque and pull up top too just a great intake
  3. #23
    never stock biminiLX's Avatar
    Beaver
    2,406
    Go with the 347, have the heads cleaned up it they're off and definitely change the intake. I like the Holley idea (although the lower should be ported and even welded on #1 for max power) or the TFS R. You could also go with a gigger TB/meter and 4" Anderson powerpipe. Stock block NA at the this level is fine probably shift 6500-7000 range, should make 450hp range depending on cam and RPM, keep a 26-27" tire or you'll want more gear.
    Good luck, should be fun.
  1. Ford 347 Stroker Short Block Engine Motor Mustang
    By cshammon in forum Ford Vehicles
    Last Post: 12-15-2010, 07:52 AM
  2. 408" SBF 351W Stroker short block engine $700 OBO
    Last Post: 07-16-2010, 07:43 PM
  3. Weekend Plans
    By wickedsnake03 in forum Meets & Events
    Last Post: 06-27-2009, 10:37 AM
  4. engine opinions
    Last Post: 05-25-2008, 11:01 PM
  5. Hypothetical engine build--opinions wanted
    Last Post: 05-12-2007, 07:21 PM
