Page 8 of 13 FirstFirst ... 678910 ... LastLast
Results 141 to 160 of 252
Thread: Capri Winter Upgrades
  1. #141
    Somerset Co.
    2,907
    Just trying to keep up with you :D Not sure what wins, Sawsall on the Capri or alternator on a Pinto ;)
    New improved packaging after I saw another doctor today. Nicely wrapped and now has a roll bar ;)
    At least it's not on your shifting hand... I always seem to mame my right hand.
  2. #142
    Lol Greg, several have pointed that out. It will likely be well on the way to healed before I get to drive it anyway :(
  3. #143
    Somerset Co.
    2,907
    I got my first 3 fingers on my right hand in the fan on my welder at work (steel fan) on a Friday morning and after 15 stiches went racing Saturday night. I wore a welding glove on my hand lol... RPM's make the pain go away.
  4. #144
    Jun 2007
    2,108
    The panels bend around the back and have thin weatherstrip ;)
    Nope ... wifey said do you need to go to the ER, no hesitation I said yes, and now ;)
    Race thumb!
  5. #145
    joe THE BIG KOALA's Avatar
    Feb 2009
    Vandergrift
    1,117
    Hey Bob you need to color that bandage black.
    2019 Hellcat
  6. #146
    Bob the car is coming along nicely but your not suppose to do mods to the thumb
  7. #147
    never stock biminiLX's Avatar
    Beaver
    2,406
    Way easier ways to take weight out of the car bro ;)
    Glad you're OK, lay off the imported Chinese beer while building :)
  8. #148
    Ed - You might notice it wasnt the right hand ;) Got to keep the shifter feel.
    J - Funny thing was, no beer involved, just rushing because I am traveling to the source ... Kingfisher this week (India), A wide variety of exceptional beer next week (Germany) then almost a month of TsingTao (China) ... at least it will be healed before I'm in the same country as the car :(
    Likley going to be May before it is running again :(
  9. #149
    Between trying to cut my thumb off, and travel, progress has been slim ... none the less, at least the machine shop could keep working :D
    One of the issues is with the Quick Time bell (for a 4 cylinder) being made to the V8 depth (or more acurately, the old 4 speed). At some point when I grow up, I want to try a TKO, and need to be able to swap trannies fast when needed so machining inputs wasnt a real option.
    So I took some parts to the machine shop. First we took the bell centering ring to T5 pilot and duplicated it with a longer shoulder (7/16")...
    We then took the cast early style adapter plate and machined the thickness and bore to suit the new set up ...
    So now the adapter ring installs like it was intended (only longer) and most importantly keeps the indexing ...
    Then the spacer slides over the ring ...
    In the end now, a 4 cylinder T5 is a bolt in without modification with this set-up, and everything will be set up for the other tranny options by removong the spacer and changing centering rings :D
    Then the spacer plate
  10. #150
    Beaver
    2,406
    Purdy
  11. #151
    Sorry to hear you hurt yourself Bob! Reminds me of when I was replacing a clutch in my '88 GT in a gravel driveway and pulled the tranny out and...uh...gravity helped bring it down and smashed the tip of my left ring finger. 80%+ severed / squashed above the top knuckle. Man did that suck. I remember rinsing it in the washroom sink, trying to get all the pieces of gravel and dirt out, with my good hand underneath, just in case the tip of my finger would fall off and try to go down the drain... Good times...good times....
    Did I mention this was a few weeks before my wedding? My fiance ( now wife of 17+ years ) was thrilled to say the least.
    After returning from the hospital with a bunch of stitches I did manage to suck it up and finish the job with a buddy. That sucked too...
    Get well soon!!
  12. #152
    LOL, you know the old sayings, cuts heal and chicks dig scars ... just going to add a little more character ;) I'm pretty sure there is nothing in my garage that I could expose an open would to that would be worse than what it saw in India ;)
  13. #153
    Decided to pass on J's suggestion to paint the cardboard and got the fillers for the intercooler ducts made tonight. Tough thing to get pictures of ...
    I still have one piece to make as a filer in the bottom ( piece of aluminum angle)... Unfortunately, while I was cutting that I stuck my left thumb in the sawsall chuck, ripped the nail back, cut it about 1/3 the way through, and broke the end of the bone ... a trip to the ER, a bunch of stiches, and it should be alright ... Coolness was they sewed through my nail to hold it on / together :D
    I did my finger last year while working on that Damn Go Kart of mine!! I really kicked it hard after the hospital trip!!!!
  14. #154
    Quote Originally Posted by racefan View Post
    I remember that ... I think you had about the same packaging on yours that I do now ... Stiches come out tomorrow, then they said just some kind of brace for the bone.
  15. #155
    Feb 2009
    Vandergrift
    1,117
    sorry to hear you need a brace for your bone
    2019 Hellcat
  16. #156
  17. #157
    Quote Originally Posted by bossman View Post
    huhhuhuhhuuhhuh he said bone ... if it makes you feel any better, I needed the biggest brace they had New improved thumb ...
  18. #158
    Talk about crazy stuff ... Basically $100.00 for fluid and filters (rear, trans, engine, and fuel) ....
    Also got a new fire jacket ...
  19. #159
    Member gtboost02's Avatar
    Dec 2008
    latrobe
    45
    handy
    that really sucks bob thats your shifting hand to.
    CHUCK 87 TURBO-T 89 LX
  20. #160
    Beaver
    2,406
    There goes the hand modeling on the side ;)
  1. Winter Capri Upgrades
    Last Post: 03-31-2013, 10:23 AM
  2. 2011-2012 Capri Winter Upgrades
    Last Post: 04-06-2012, 10:33 AM
  3. Winter Capri Upgrades ...
    Last Post: 04-07-2010, 11:51 PM
  4. Winter Upgrades
    Last Post: 02-08-2009, 02:27 PM
  5. Winter upgrades
    Last Post: 09-11-2008, 06:20 PM
