Hi folks - I'd like to be able to take my '66 to BeaveRun for some road course fun, but to do that I need 3-point seatbelts. Currently, my car only has the 2-point belts like they had in the '65/'66 Shelbys ( 3 inch competition belts ). They were fine for Jerry Titus and others back in the day, but nowadays I guess they just aren't safe enough. Hey - I can't drive like Jerry Titus, so I'm all for being as safe as possible if I'm out on the track. Ok now...watch how this will snowball...
My car isn't crazy quick...just low 12's now. The stock seats don't offer much lateral support by today's standards. I don't like the look of 3-point belts in the early cars, even though they can be retrofitted relatively cheaply. So I started looking into some upgrades ( yeah, here we go... ) - like the Procar Rally seats they use in the Eleanor cars. I sat in them out at Summit and dang they're nice!( photo below )
5-point harnesses and a rollbar would be my next steps. The harnesses with the cam-locks really seem to be nice and relatively easy to use - not as cumbersome as the older-style pieces. I was thinking about something like these from G-Force... ( below )
Now - I've seen harnesses that just attach around the rollbar, and others that you have to weld belt mounting tabs to the rollbar ( and maybe to the floor? ). Is one way better than another? What is required for drag racing? Is it safe to assume that if a rollbar is adequate for drag racing ( assuming that I'll be running less than 11.5 seconds at some point - if that is the point at which a bar is required?? ), then it would be ok for a road course?
What type of rollbar would I need for drag racing - is a 4-point ok, or would I have to go with a 6-point or ?? I doubt the car will ever be a 9 second car, but I could see it going deep into the 11's or high 10's one day with more cubes. If you guys could let me know what kind of bar is needed for the various E.T. ranges that would help. I'm really hoping a 4-point will be all I need, as 6-point cages are a good bit more intrusive. Also - I know the over-the-shoulder belts need to be mounted at a certain height - slightly below the shoulders? - to be safe, so I'm thinking I'd like to have a removable crossbar running across the hoop, to which I could mount the harnesses. That would allow me to remove the crossbar when I have to put the family into the car - I don't want anyone banging their heads on a crossbar if I have to slam on the brakes.
What type of material should the cage be made of? I guess chromoly tubing is the strongest, but I have no idea what the rules require.
So basically, I want to make the car safe at the strip and road course, and eventually a good bit quicker ( that part involves a whole other bunch of upgrades down the road... ), while doing more drag strip and road course duty. It will always remain a 95% street car - I just want it to be safe and legal for all the other stuff. If I have to spend a little more $$ to get it to that point, I figure that is the smart way to go.
Feel free to chime in with any suggestions or whatever. I'm at the front end of the learning curve here.
Thanks for the help!
Ron
