Results 1 to 8 of 8
Thread: smog pump delete questions
Hybrid View
    Aug 2010
    connellsville
    160
    hi guys i'm looking to eliminate the smog pump and all the tubing from my 91 gt just wondering what all i need to remove and what can i plug the holes with in the back of the heads the cats are already off the car cause i have an offroad h pipe just not sure what i need to plug off and what vaccum lines need to be plugged any help would be great thanks.
    Gibsonia, PA
    323
    Mine may be a bit different because mine is a 95 car but...
    You can buy thermactor plugs. Lou may be able to hook you up with them but if not you can get them at Summit and other places. I run GT40P heads which do not have thermactor holes so I didn't have to do that part. Like these:
    I traced all of the vacuum lines from the smog pump and capped/plugged them all and ripped them all out of the engine bay. Some went into the fender so I took off my plastic inner fender and put vacuum caps on the little rubber "tree" in there.
    Take the pump out and all hoses/lines. You will have one hard metal line running to where your cats were. I had to support my transmission and remove the transmission bracket to get the hard line out of the car wihout destroying it.
    I ran a smog pump eliminator pulley that I got on here used.
    You can run a shorter belt and avoid the pulley if you want.
    I ran the pulley because I eventually added a blower kit which assumed that a smog pump (or pump eliminator pulley) was there.
    One caution about the eliminator pulleys is that the diameter of the pulley is smaller than that of the real smog pump pulley. So my blower belt was too long and I had to search out a new blower drive belt anyway.
    Good luck!
    Getto it an use spark plugs and brake end off
    out in the woods
    4,948
    pull all the smog stuff off, whatever vacuum lines you disconnect put a piece of hose with a bolt on it. back of the heads pull that pipe off cut the ends off it and flip them around and bolt to opposite head(da backs are flat and will cover holes)use same 1/2" bolt to reinstall them. clamp another piece of hose w/bolt onto the pipe down on hpipe.
    buy shorter belt unless you got the (not-needed) smog emil kit.
    done this many times works great, (doesnt cost a thing if you got clamps/hose layin round) buyin belt is only cost.
    Aug 2010
    connellsville
    160
    now can i remove all the tubing and hoses that sit just above the header or do i need to leave those alone and plug them off
    out in the woods
    4,948
    yep take it all out
    Aug 2010
    connellsville
    160
    ok thats for the advice guys
    out in the woods
    4,948
  1. Belt Length For A/C And Smog Delete
    By Dickbag 5.h0 in forum Fox-SN95
    Last Post: 06-14-2012, 04:17 PM
  2. Smog pump delete?
    By PITT40 in forum Fox-SN95
    Last Post: 06-18-2010, 09:32 AM
  3. FS: Smog pump delete kit
    By blkp42e in forum Ford Vehicles
    Last Post: 03-24-2009, 01:09 PM
  4. Smog Pump and A/C delete question for my 85 hatch
    By TheGreatWhite in forum Fox-SN95
    Last Post: 10-25-2008, 07:35 PM
  5. smog delete
    Last Post: 03-28-2007, 09:53 PM
