Disco louvers...
289 slabside cobra![]()
6S1941![]()
LOL ... i'll let you have at it first then :D For me, I look at it is as something I can add after I try all this other stuff, then go here if needed :D
Yes, but they need the Disco flares to be effective. The flares create the low pressure area behind the car :D
Have a look at the pictures of the Cobra style extractor vents above and the Shelby extractor ... how hard would it be to make sometrhing more functional like the extractor hoods but with a flange like the Shelby vent out of glass ??? Sort of like two big NACA ducts but to accept the ford grills ... We might need to talk about bonding a plate into my cowl opening anyway :D
One other thing to discuss .... coatings and wrap
Several of us have mentioned wrap. It works and is semi-cost effective but has not held up well for me. It will survive a season if I coat it with ther spray, but if I have to handle anything after that the wrap turns to dust.
I will be coating some things with this ...
http://www.techlinecoatingswebstore....tin_Black.html
I'm going this route because it will air cure ... One of the TurboFord vendors uses this stuff on his headers he sells and said it holds up best of all of their stuff, including the "Turbo X" product. There are a number of home coat systems out there but this one seemed the closest to DIY with home tools I could find. Some time soon I will coat my stuff and keep that updated.
That coating is expensive. You should buy a gallon and let me use some:D. I havent had any issues with the wrap, but my car only see's about 500 miles a year on sunny days. DEI makes a Titanium exhaust wrap that looks like a better quality wrap.
http://www.designengineering.com/cat...-lr-technology
Check this out, seems a bit overkill.
http://www.designengineering.com/con...get-more-power
LOL ... Should have caught me earlier with that offer ... I only bought 4 oz ... It seems that it really will go a long way, but that is TBD ... Probably going to get around to it over Christmas holiday. There are eBay and online sellers that offer it a bit cheaper ... my issue is you never know how it was stored, how old it is, etc so I went right to TechLine
You only have half as much exhaust as me, maybe less, so 4oz may do it?
How are you going to apply it?
Found this on crownvic.net, apparently it works on a vic. LOL
"Best part is is that it's functional too. I did some data logging before and after and with identical weather conditions with the outside air temp only one degree different, my intake air temps came down from 109 degrees to 84 degrees."
I dunno how you guys deal with a "whole" engine, I got my hands full with half the crap :D
Yeah, no air deflector on the Capri RS ... You have to remember that this was a different nose to start ... Mercury took the normal Capri nose that sort of tucked under like a GT of the era, cut the bottom off, then put the 79 pace car air dam and fender extensions on it. Not sure they did a lot of engineering for it on the Capri ;) The plastic filler between the opening and the core support is bolted on where a defelctor would normally fit.
http://forums.corral.net/forums/show....php?t=1237878
I'm still on the fence, thinking of even opening it up more and making a floating oval or running horse, but I don't want to get too far from the clean factory look, well other than the steamroller tires
I kinda like the way it looks with the Saleen air dam![]()
I hooked you up with the grill delete with my mad photoshop skillz![]()
Running horse
Love the Photoshop skilz. Not so sold on the grill delete ?
