Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
Thread: trying to learn cams
  1. #21
    1,171
    Quote Originally Posted by fast4ord View Post
    Go with a dual pattern cam, alphabet cams are timeless, and put a 5-speed in that pig
    x2
  2. #22
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    Jared,
    go with a small comp XE 258HR cam or XE264HR. Bigger isn't always better with cams. Neither is peak power on a street car. You want to build for the highest average power & torque, also known as the areqa under the curve. When you're looking at a dyno graph, you want to tune the car to have the most amount of area under the HP & TQ curves. That will make the car fun to drive & the quickest. Forget about max HP.
    http://www.compcams.com/technical/Ca.../72-75_230.pdf
    Don't forget, you need to upgrade the springs, retainer & rockers to use a HP cam. Your stock valve springs are not up to the task.
    I may be able to help save some $$ with some used parts if you're interested.
    Mark Lowry
  3. #23
    Im about 99% sure the X & Z cams will not work on stock bottom ends.
  4. #24
    Belle Vernon
    1,294
    Jared, just take your time and do your research and you will save in the long run from having to buy parts more than once. Make a plan for what you want your goal to be, like street & strip car, track car, daily driver, dyno queen, N/A, blower, or turbo(s). Do you want auto or stick, and a 5 speed doesn't make a car fast. Putting in a cam won't give you that much HP but it does give it that lumpy idle that everyone loves. The cam is a key part in making your combo work together. It moves your power range around through the rpm's. Your combo is what makes the cam good. If you are planning on keeping the auto it is important to match the converter and cam.
    '89 Mustang GT
    '04.5 Duramax
    Jones Race Car Trailers
    www.jonesrv.com
  5. #25
    If you have a stock bottom end the "X" isnt going to fit. Forget about the Ford cams, get yourself a nice OTS Comp Cam, there like $249
    i have personally put an e-cam into the 11s NA, also a f-cam into the 10.90s with a 150 shot all with STOCK heads, and full weight cars, the fms cams are great and all of my stuff is carberated, and i know that everyone thinks that fuel injection is faster.
  6. #26
    correct the x and z will cause problems for you, stick with the F-cam, then you can go and buy a set of stock 93 cobra valve springs for 40$ at advanced auto and throw them in on top of that cam and you will be good to go....
  7. #27
    Dude....If I can sell some parts I will putting a new combo in the notch. I have a Steeda 18 in there now. It is a mild split duration cam that is wonderfull on the street with a nice top end. When are you looking to do this?
  8. #28
    Farmington WV
    4,672
    not looking to install anytime soon, just know a couple fs by members here and was beginning to look harder into it. i do want to cam this 5.0 but it wont be for a litle bit. id love to have a cam and stall before track season ends this year.
    i know of an E and an X. was gonna call summitt about the X yesterday but was too busy at work.
  9. #29
    Farmington WV
    4,672
    good to know.
  10. #30
    Farmington WV
    4,672
    keep me posted
  11. #31
    Farmington WV
    4,672
    remind me to ask you about this when i get there tonight!
  12. #32
    ok, hey Jared, ask me about this tonight. hehe
  13. #33
    Farmington WV
    4,672
    thanks for taking care of my turd.
  14. #34
    Farmington WV
    4,672
    how does this cam relate to an F cam? TF stage 1? etc?
    http://www.holley.com/510A3LUN.asp
  1. Cams!
    Last Post: 01-22-2010, 07:04 PM
  2. Cams
    By bill412 in forum S197
    Last Post: 06-30-2008, 07:11 PM
  3. Learn something new everyday...
    Last Post: 02-02-2008, 04:57 PM
  4. Hondas will they ever learn?
    By SVTGT in forum The Bar
    Last Post: 01-09-2008, 12:33 PM
  5. Learn English!
    By One Sweet Day in forum Pictures & Videos
    Last Post: 04-02-2007, 03:17 PM
