Results 1 to 16 of 16
Thread: Electric water pump?
    Considering on removing some pullies in the front end. I want to instal an electric pump but not sure what i should get. I was looking into moroso and CSR at summit"s site, but i'm not sure on they're quality of product. I don't want to buy a pump and it only work for 5k miles and need to get a new one. What are your recomendations on what to buy?
    South Hills, PA
    4,052
    street car or race car? I have a meziere and love it!
    never stock biminiLX's Avatar
    Beaver
    2,406
    x2 remote mount
    Its more of a street driven car. I guessing this mounts off of the motor in the inner fenders somewhere
    Beaver
    2,406
    Yes, makes room for turbo piping.
    They also make versions that mount directly to the radiator, pretty trick and not any more money.
    Ok i found them on summits site, but how do they plumb in? Looks like you use they're backing plate with 2 small water necks back to the pump? I'm also trying to clean up the front so I don't really want a bunch of hoses run every where
    South Hills, PA
    4,052
    you tig on two 12an male fittings to a backing plate or directly on your timing cover and run two 12an lines to the pump.
    Beaver
    2,406
    South Hills, PA
    4,052
    J you still have a horn? lol
    Beaver
    2,406
    Horn, wipers, all that 'street car' stuff ;)
    Ok, but where does the lower rad hose go to then. The upper looks like it does to the same spot
    Never mind i reread it. It has 1 inlet and 2 outlets. Inlet is from the radiator and the 2 outlets to the backing plate.
    Also what alternator bracket is that? Not sure if it'll work on my 94 but its worth a shot. If not i'll have to make a billet one
    Beaver
    2,406
    Just switched a March bracket to other side, crank only runs alternator.
    South Hills, PA
    4,052
    whats an alternator? haaaaa time to switch to 16v J dog
    Beaver
    2,406
    Nope, think 'street car' ;)
    And they actually make a 16V alternator somewhere I believe.
    Sorry to bring this from the dead but....
    I ended up buying a Mezeire remote mount pump, but got the wrong one that has only 1 outlet. My concerns are about plumbing it in having 1 out port and 2 hole on the backing plate. Can I run 1 hose from the pump to the backing plate and basically plug shut the other hole on the backing plate? I ask this because I can not find and A.N. T-fittings that are A.N.-20 on 3 sides. Also would there be a way to plumb in the heater?
  1. Meziere electric water pump
    Last Post: 05-28-2012, 09:13 AM
  2. 1994-95 Mustang Meziere Electric Water pump
    By Rio94gt in forum Ford Vehicles
    Last Post: 04-22-2012, 08:41 PM
  3. Need a water pump
    By Tony71502 in forum Ford Parts
    Last Post: 08-12-2009, 08:10 AM
  4. 5.0 Water Pump
    By day9033 in forum Ford Vehicles
    Last Post: 05-07-2009, 05:40 PM
  5. Installing the Meziere electric water pump?
    Last Post: 07-15-2008, 05:21 PM
