Results 1 to 7 of 7
Thread: heat not working in fox
    2,247
    The heat in my fox does not want to blow when the car is on. BUT when the engine is off and the key is turned air blows just as it should. has anyone heard of this? All my fuses are good and i'm not sure where to look next.
    Black
    1,220
    Do you mean the blower motor works with the KOEO and doesn't work with the KOER? If so I would try wiggling the ignition key or turning it back slightly when the car is running to see if it starts working. If so you probably have an ignition switch problem. If you mean the air doesn't blow out of the right spot you could have a broken vaccum line or bad vaccum switch on the heater control.
    LowHill
    2,679
    I had a problem like that once and it was the ignition plug
    2,247
    Not sure what the KOER or KOEO is...I'll research.
    and it blows just as I have it set when the key is turned but the motor has not been started. As soon as the car is stated, the air does not blow what so ever, as if it's set on "off."
    Sometimes when I take a sharp turn in will kick on...or randomly while cruising down the road.
    The same goes for any air coming through the vents, not just the heat.
    Black
    fairmont,WV
    1,352
    KOER= key on engine running
    KOEO= key on engine off
    XXX RWHP
    XXX RWTQ
    Ignition switch harness may be coming loose. Or the ignition switch could be bad.
    2,247
    In that case, yes that's exactly what's going on. Sometimes it shorts when i try to start it and i have to undo the negative battery cable and reconnect to start it. That lead me to believe it IS something in the ignition now that i think of it...
    Black
  1. TFS Street Heat / Track Heat 3/8" Spacer
    Last Post: 12-02-2013, 06:46 PM
  2. WTB: working Maplight for fox
    By White5.0 in forum Ford Parts
    Last Post: 06-18-2010, 02:24 PM
  3. Who is Working Today?
    Last Post: 07-04-2007, 03:42 PM
  4. working with fiberglass
    By blkp42e in forum General Tech
    Last Post: 06-08-2007, 09:44 AM
  5. Fox Lake stage 1 ported Track Heat EFI intake
    Last Post: 05-20-2007, 08:15 PM
