Results 1 to 13 of 13
Thread: torpedo heater
    Aug 2010
    connellsville
    160
    torpedo heater
    hi guys and gals i'm looking for a cheap torpedo heater for my small garage can't get nothing done on my car in this cold.
    Fuwkawee
    5,151
    X2, I've thought about buying one also so I can get modding on the 2011.
    17 Ram 1500 Big Horn Hemi
    16 Comp O GT Performance Pack
    Your mom cwh19's Avatar
    May 2009
    Greensburg
    1,383
    I have a 30k-80k BTU one from lowes. Its only 100 bucks and it heats my large one car, non-insulated block garage to 60 degrees in about 5 minutes. I would definitely recommend it.
    15gt
    94gt
    Can you post up more info on it? Kerosene or propane? How much fuel does it use? Brand name / model #? Thanks! I need one too - my garage door doesn't seal that well and until I replace it I need something like this...
    Yeah, details are appreciated. I couldn't heat mine but it would be nice to knock the chill out. I was planning to go shopping for one tomorrow.
    May 2009
    Greensburg
    1,383
    I lied, it only goes to 60k btu. But even so it still works the same. Its propane. There is a chart break down about fuel usage. On low it lasts 14 hours of run time I believe. I turn it on high for about 6-7 minutes then turn it down because it gets too hot. Here is a link.
    http://www.lowes.com/pd_154996-88644...opane%2Bheater
    15gt
    94gt
    Thanks for the info!! Seems like a nice unit! I'll have to run to Lowe's and check them out.
    I picked up one of the $100.00 heaters from Home Depot today. I will report how it works later in the week.
    May 2009
    Greensburg
    1,383
    I went to home depot first but they were out. So I went over to lowes and I got the last one. They are the exact same heater.
    15gt
    94gt
    LOL, well yours is black and diamond plate looking but mine says "pro" :D Tough decission ;)
    Aug 2010
    connellsville
    160
    thanks guys i bought a $ 100 one from tractor suppy in mp it was the biggest peice of crap the damn thing caught on fire in the first 5 minutes of turning it on the fan inside stopped working DO NOT BUY it's a master 50,000 btu from ts. but what i'm really looking to buy is a small used kerosene torpedo i'll never buy a propane torpedo one again after my experience today thanks guys
    Under PSI Black Vert's Avatar
    Cranberry Twp.
    344
    I've had a Mr Heater 75,000 btu torpedo for 5 years now , have'nt had a single problem with it, just add kerosene and flip the switch. I use it in a 2 car garage, heats up to 70 deg in less than 5 minutes in an uninsulated garage. Its really too big for a 2 car garage, a 50,000 btu or less would probably be more ideal. It has a thermostat, but its either a on or off type heater. Downside is that its loud and smells, you have to crack a window to keep the smell from going into the house. But it gets the job done and fast.
    http://discountportableheater.com/to...rosene-heater/
    I like the Reddy Heater brand (I think that's how it's spelled), after seeing a couple of my buddies with them. I bought mine used in '03, and it works fine. 55k btu in a 4 car detached garage, and if it's real cold out (20 or colder), I'll go out and turn it on for a half hour and it will have knocked the chill off. It is a little small for the 4 car, but directing it in the area I'm working, it's comfortable enough. It is loud, and can get a little fume-y.
    ChuckT
    Sponsored by
    Millerstown Pic A Part
  1. heater for garage
    By 85stang in forum For Sale
    Last Post: 11-18-2010, 01:54 PM
  2. heater question
    By 85stang in forum General Tech
    Last Post: 01-03-2010, 03:40 PM
  3. Best heater core to get?
    By lib88stang in forum The Bar
    Last Post: 02-07-2009, 04:21 PM
  4. Heater core how to
    By wick in forum General Tech
    Last Post: 09-23-2008, 11:47 PM
  5. wtb: TORPEDO HEATER
    By madmaxin22 in forum Ford Parts
    Last Post: 01-23-2008, 08:47 PM
