Results 1 to 13 of 13
Thread: Any transmission rebuilders upgrade a T5?
    Gibsonia, PA
    323
    I am looking for someone to rebuild a T5 and put some better internals into it (like G-Force or similar) including a rear bearing retainer. Also looking for a taller 5th gear for highway like a .60 .
    Are there any shops or individuals around that anyone can recommend?
    Thanks!
    We can do this for you! Call the shop 724-964-8419.
    Polar Vortex
    6,031
    I know wick here on the boards does work on transmissions also. Pm him.
    x2 ... Rob rebuilt Bob's ( 94Cobra ) 3550 and he has been very happy with it. Rob is a nice guy and his GT is one mean ride!!
    Mt.Pleasant pa 15666
    2,832
    x3 he's also good @ hardening the shaft!
    plum
    487
    x3 on Wick, knows his chyt!!
    South Hills, PA
    4,052
    I would't go to him HAAAAAAAAAAA, isn't this illegal on this site to do? I know I got yelled at for it.
    i have rebuild kit for a t5 if you need one.
    2,832
    Quote Originally Posted by Mater View Post
    Quote Originally Posted by 89 vert View Post
    U should be x4
    wtf are u a baby or what?
    South Hills, PA
    4,052
    U should be x4
    BM...
    2,832
    u blow mice?
    South Hills, PA
    4,052
    I sure do, it reminds me of when we are together :)
    Gibsonia, PA
    323
    Thanks for the replies and recommendations, guys.
    I bought Mark's (1badnotch) Tremec setup that was posted on here so I will not be needing the T5 upgrade.
  1. Replies: 13
    Last Post: 01-13-2014, 10:10 AM
  2. Any local T56 rebuilders you trust?
    By Mark Aubele in forum Other Makes / Models
    Last Post: 04-05-2012, 08:17 PM
  3. Any local fuel injector rebuilders/cleaners
    By frankstang in forum General Tech
    Last Post: 01-02-2010, 07:51 AM
  4. Supercharger Rebuilders
    Last Post: 06-18-2009, 02:52 PM
  5. Any manual trans rebuilders local?
    By FineLineMtrSprt in forum General Tech
    Last Post: 06-25-2008, 07:09 PM
