Results 21 to 40 of 56
Thread: Turbo 427 rebuild
  1. #21
    never stock biminiLX's Avatar
    Beaver
    2,406
    http://www.steelcitystangs.com/forum...ad.php?t=21842
    Think it'll go faster thisyear? ;)
  2. #22
    3,316
    I got about 2.5 pressure ratio and between 95 and 125 lb/min based on my calcs (depending on boost) and this is close to my compressor map:
    http://www.turbobygarrett.com/turbob...8compmap_e.jpg
    Its a GT4788 (which they call a GT4718) and its a 1.08 A/R so it will be close to the efficiency island. We'll see, whatever it takes to run the number
    I'm loading some vids now from the chassis dyno and auto track test, will post soon.
    Nice! That turbo looks like its going to be perfect for your application especially at a 2.5 pressure ratio and 95-12X lb/min of air.
    I cant wait for vids! :)
  3. #23
    Beaver
    2,406
    Thanks man, I'd love to have a 91mm and a compressor map shorter and wider to the right, but I think it'll do fine
    I will keep it updated, build/parts pics, engine dyno vid and chassis dyno vid coming soon.
  4. #24
    Apr 2009
    Allison Park
    538
    J
    Good luck with the build! Let me know when it is my turn for a ride!!
    Randy
  5. #25
    Beaver
    2,406
    Ed Curtis delivered a few presents to my engine builder:
    Too bad I didn't get to see them in person :(
    These were the last of the hard parts, all that is left is to mock up the 1.7 Prob shaft rockers, order some Smith Bros. 3/8" pushrods and port match the 2828 Glidden Super Victor intake.
    Dyno day for NA carb break-in scheduled for Sat. April 23rd.
    Doing just like I did with the previous version of this engine, just a break-in procedure with a carb and no real tuning for power. Last made 520/520, this version will be same compression, increased rocker ratio and bigger heads/intake. I'd like to see 600hp NA but NA numbers aren't what I'm after ;)
    Plan on flowing the heads and intake and then both together. If I still have the old heads and intake I will do the same with them just for data.
  6. #26
    Beaver
    2,406
    As soon as its off the engine dyno its going to Street Lethal to get serious!
    I need to update the build thread, but I also sold my GT4788 turbo and air-air cold side intercooler. Custom 88mm 275X legal new model borg-warner on way from Reed at Work Turbo and I will be doing an under-dash air-water set-up with rear facing TB.
    I had mocked this up but it was just too tall:
  7. #27
    Reed at Work Turbo
    Work Turbo??? Is this the same Reed that was at a well known shop? Link to your guys?
  8. #28
    Lookin sweet J!!!!!!!!!
    Cant wait to see what this new combo will do!
  9. #29
    Beaver
    2,406
    Yep, same Reed from Supernatural Turbo but he and Matt his partner split that amicably so he could do his own thing just with turbos, Supernatural may become something more comprehensive with turbos, Work will be actual turbo units only.
    He doesn't have a site up yet, he wants pics of my car to include in the new website launch.
    This new 88mm is a pre-production Borg-warner S500/510 big boy that is supposedly the best cast wheel 88 you can buy now. I'm keeping it 88 in case I want to run in some 88 only classes for fun, I think it will upgrade as big as 114mm on the compressor.
    Thanks Robert, when your's planning on testing?
  10. #30
    Gotcha, didnt want to start something and say Supernatural until you confirmed it. Reed really has a good reputation with turbo's, as long as he keeps that up he should do fine on his own.
    Is the 88 mm a limit in x275 or what classes?
    I guess I don't spend enough of time on YB, I'm not fast enough to hang out with the cool kids there ;)
  11. #31
    Well J....what's the scoop on this past weekends dyno romping?
  12. #32
    South Hills, PA
    4,052
    dyno operater got sick, he couldn't go.
  13. #33
    Beaver
    2,406
    Yeah, fking shingles :(
    That can really knock you down so I'm giving him a pass but it really needs to happen this saturday or else my schedule is screwed.
  14. #34
    I'll run that dyno for you...just say the word. ;)
  15. #35
    Any updates J ?
  16. #36
    Beaver
    2,406
    Yep, crank/rods I bought are high end pieces (good) but set-up for a piston centered rod (bad). Getting piston spacers made now, not a big deal but dyno will now be Sat. June 4th. Also found excessive wear on cam gear, so new billet core hydraulic roller arrived yesterday.
    More delays, but F**K it, it needs to be right, I'm not rushing it.
    On a side note I got to inspect the heads and ported intake and they are things of beauty, way better in person.
  17. #37
    yes it pays to do it right , while you have the chance
  18. #38
    Any updates on getting the new turbo on and car tuned?
  19. #39
    Beaver
    2,406
    Wish I had a good update John.
    The motor and turbo have been at Street Lethal since early June but there are many things to do (rear fender mods, paint, fabbing headers, rad/fans, intercooler, etc.) and they are trying to get a break in their schedule to get it in and dedicate the time (prob 6-8wks) to complete everything.
    Hope to make some passes late Sept/early Oct. :(
    315/60/15 DRs and 15x12 are on the car and look killer, the entire interior and minitubs have been Lizard skin coated (sound deadener/ceramic heat protection) and the cage painted with a nice fine bedliner type coating. All that looks great, just need to move onto the stuff that makes noise :)
    There will be updates when things get moving.
  20. #40
    Sounds good J...didn't realize all that other work was getting done as well.
  1. Turbo 427 NA engine dyno guess
    By biminiLX in forum Fox-SN95
    Last Post: 06-13-2011, 10:12 PM
  2. Newbie with a 427
    By Naste95 in forum Welcome New Members
    Last Post: 01-09-2011, 03:09 PM
  3. Spec 3+ clutch vs. Turbo 427
    By biminiLX in forum Pictures & Videos
    Last Post: 01-02-2010, 09:33 PM
  4. 427 side oiler
    By pwtmxracing in forum Ford Parts
    Last Post: 03-01-2009, 09:01 PM
  5. Roush 427
    Last Post: 12-13-2008, 10:17 PM
