I am posting this under my friend Butlers account... I will plan to sign up in the next couple days... BUt I am stumped right now, and need some advise/insight/direction....
90 Mustang GT 31 Spline Axles. Took the Auburn Pro out because it was not gripping any longer. Switching over to the Ford Trac-Lock (31 spline Explorer) diff with Carbon discs just to make it easier when to fix when it wears out.
I had a friend helping me on it, and he has left me hanging in the cold for about 3 weeks now. I guess I know why now...
Somehow something was not set up right when the new bearings were pressed on, and the ring gear bolts (3) are smashed and mushroomed. The sides of the carrier (where the shims sit) have indentation/gouges pressed into them somehow. And worst of all my Shim holders (lack of better term) and freakin scrapped and gouged like they were chiseled on... Other issues as well, but just trying to keep my blood pressure under control.
So now I am trying to start fresh, and I have a few questions...
1. Do the Carrier Shims ride against the bearings so that a marked up edge of the carrier itself will not create and issue?
2. If 2-3 of the ring gear bolts were smashed like a mushroom after being torqued down what are the odds that it bent/tweaked or just trashed the carrier OR ring gear???
3. I had a shim on each side of the Carrier that was a 2 piece shim, and the real thin shims went inside the 2 pieces that locked together. Now one is egg shapped and both are gouged up. Does Anyone know where to buy those? they are just 2 pieces that fit together to work as one.... Much easier than just stacking shims...
Sweet setup for shims until they got fvcked beyond belief...
And the bad one...
