Results 1 to 11 of 11
Thread: Headlight switch problem – 87 Fox Body
    Cheap SOB
    Baltimore, Maryland 21236
    288
    I had a problem with my headlight switch. Sometimes the dash lights would not light. Once or twice the headlights would not light. Simply wiggling the switch took care of the problem. I bought a new switch from Blue Oval Industries and was going to install it while I had the dash out, but I found a surprise. See the picture below.
    Is this a common problem? Do they sell this connector on a pigtail? Do I have to swap the whole harness? The harness appears to be most of the dash wiring. It goes though the firewall and connects to the lights.
    Quote Originally Posted by DRRummel View Post
    If it's a GT 87-93 a potential problem may occur when using a jumper wire so the fogs can be operated without the headlights needing to be on. This wiring mod is said to cause the wires to become hot from the current draw. Is the harness pigtail modified in any way?
    Mt Pleasant, PA
    4,905
    That is fairly common. I have the repair plug and harnesses in stock.
    If you wish to wire you fog lights as mentioned above, you MUST wire in a relay!
    Member madmaxin22's Avatar
    on the red belt
    853
    did that fix... pretty easy... if you pull your covers off the column and pull the multifunction switch out, your connector into that might be melted as well causing your other problems....
    2014 RAM QUAD CAB 8SPD
    Cheap SOB
    288
    This is a stock LX. The only modifications were a set of Cobra R wheels and window louvers. No jumpers here, just a loose connection is my guess.
    Cheap SOB
    288
    How do I get one and how much is it?
    Call 1-888-925-7669 Ask for Lou (Sonic03snake on here)
    Mt Pleasant, PA
    4,905
    Im off tomorrow but ill be back in on Monday.
    Cheap SOB
    288
    Thanks, Will do.
    Cheap SOB
    288
    All the connectors attaching to the steering column look good. Thanks for the warning.
  1. Replies: 0
    Last Post: 06-03-2014, 07:46 AM
  2. Fox Original Headlight/Side Marker/ Park Lamps
    By Zoom50 in forum Ford Vehicles
    Last Post: 04-03-2014, 08:22 AM
  3. My old 91 fox body.
    By 89stang in forum Fox-SN95
    Last Post: 06-03-2013, 11:00 AM
  4. 79-86 headlight switch bezel
    Last Post: 07-14-2008, 07:34 PM
  5. Replies: 2
    Last Post: 03-21-2008, 12:51 PM
