Results 1 to 3 of 3
Thread: Rear Disc Questions.....
Hybrid View
    Carpe Diem Kuneff's Avatar
    Dec 2010
    West Virginia
    46
    I have a friend who was talking about taking his Fox 8.8 rear axle and having Ford 9" axle ends put on it. My first question is... How much stronger does that really make it??? My next question is what Rear Disc Brake setup would he need to go with after that?
    I was guessing that he would need to get Explorer 8.8 rear disc's, but just not sure...
    Thanks in advance for your input.
    Education is the most powerful weapon which you can use to change the world
    never stock biminiLX's Avatar
    Beaver
    2,406
    Quote Originally Posted by Kuneff View Post
    That is a nice upgrade because you eliminate the need for C-clip eliminators and weld the tubes at the same time, so not necessarily just for strength as welded 8.8 axle tubes does the same. But yes, 8.8s should have the tubes welded for strength for drag launches (find Ares' thread on that ;) ).
    I have a 9" and use the SVO/Explorer rear disc but many options exist from all the major companies---Wilwood, Baer, Strange, etc.
    Mt Pleasant, PA
    4,905
    Going to a 9" end eliminates the c-clip axles, its great idea for performance oriented applications. Just be sure to have the correct 9" ends installed, there are several different sizes. The most economical one is the large bearing end that accepts the ford explorer rear disc setup.
  1. FS: 94 - 98 Mustang 8.8 disc brake rear
    Last Post: 08-08-2011, 01:53 PM
  2. FS: 8.8 Solid Rear Axle. Cobra Brakes! Disc-to-disc.
    By 01CAMMER in forum Ford Vehicles
    Last Post: 12-11-2010, 11:10 AM
  3. what rear disc brakes?
    By yeahloh95 in forum General Tech
    Last Post: 07-31-2009, 01:50 PM
  4. 5 lug swap and rear disc
    By stangr6man in forum Ford Parts
    Last Post: 04-10-2009, 05:17 PM
  5. Replies: 7
    Last Post: 04-15-2008, 10:51 PM
