Let's see if this worked:
[ame="http://www.youtube.com/watch?v=D1Wc0dL-dPM"]YouTube - autotesting.wmv[/ame]
Car looks & sounds great J!
That car of yours makes some serious steam bro!
Do you have a line-lock?
Doesn't seem like your holding your burnout long enough.... maybe something to think about?
Car looks like it pulls to the left some & then you steer it back right....maybe a little ARB adjustment could straighten that out. Or maybe you just got out of the groove a hair.....kinda hard to tell from the camera angle.
What kind of 60's are you pulling?
Are you launching off of a transbrake in the video?
Sounds great - sits great - and runs AWESOME!!! Keep the vids coming!!
like i said before,bad a## car !![]()
Thanks guys, looks like the upload worked.
I apologize for the motion sickness, my dad was learning the cam
The dyno vid was on a loaded Mustang dyno at about 15psi.
Unfortunately the battery died by the time we got to tuning at 19psi, but I can tell you it sounds much more pissed off at 19psi
Rob:
Yes, car has line lock, 2-step, AMS 2-stage boost controller but unfortunately none of those were working that day as the auto swap was finished the day before. The vid is from a track rental in August only off the wastegate spring at 13.5ish PSI. Hell, I had helped finish installing the rear gear at 4am and had to load the car at 7am, so quite a few things weren't perfect---not to mention the 92* heat.
Those were my first burnouts and track passes ever in an auto, huge difference compared to the stick, felt like a fish out of water big time.
Good eye on the suspension too, the car's anti-roll bar was binding and someone had changed one side coilover setting so the car was not set-up correctly. It has since been back to Team Z but unfortunately the flexplate/starter ate each other the day we picked it up at Team Z for the 2nd outing, starting the tear-down in the other thread.
Launches were off the transbrake at 2-3psi basically just to load the suspension, it now builds boost MUCH better on the TB with the 2-step.
60' were high 1.5s, best pass was 9.60 @ 148 with 1.58 60'
It went 1.51 60' with the stick (9.84 @149 at 15psi best).
Neither combination had been maximized due to limited testing time, I hope to change that later this year.
Plan is to have some 20psi dyno vids from Street Lethal later this spring and consistent mid-8s later this summer, you'll get vids of that too
sick car! sounds awesome
DD: 99 Civic Si
Toys:
07 GSXR 600
Sounds and runz pretty gooood!! Testin at Milan I see, I was just wanderin how's come their thou!? N ought ohhh, its gonna be chute pullin time soon, lol!
Bu-2000-bash
ALLSQUAD
Steel City Muscle Cars
CarCruises
Flashlight Drags
NMRA
UMTR
Modded Mustangs
NHSCC
Thanks fellas.
I'm from Toledo, OH originally and its only about 30min from Milan, so its probably there and Norwalk where I run most.
Car is now in PA up at Street Lethal and should make some passes at PRP this year
Also has a shoot hanging off the back now, going to need it this year
I can totally relate to new combo jitters/testing....lol
Sounds like you got all of it figured out and that thing is going to be a real handful once everything is ironed out and clicking together!
Good luck with everything and let me know if you ever need any help or assistance with anything!![]()
Thanks man, hope to see you at the track this year, same for me if you need anything give me a ring.
Computer/RPM thing resolved yet?
very nice, is that car mini tubbed? What are the specs on the rear wheels, very nice stance.
http://www.fquick.com/celeste
1989 Mustang GT 663 RWHP
1991 Strawberry Notch
1992 Calypso LX
MM&FF Article
5.0 Article
that thing sounds mean cant wait to see it run this summer gotta love thoes turbo cars![]()
