Results 1 to 4 of 4
Thread: Front Drag spring ???
    LowHill
    2,679
    How much should I cut off the front coils of a drag spring to not have the 4x4 look? Id like it to sit near stock height in front or a lil bit lower.
    South Hills, PA
    4,052
    one coil
    my 93 sat lower even with the drag springs but if you cut a coil it will sit about an inch or more lower and they will be alot easier to put in .
    LowHill
    2,679
    I have a set of ground pounders and I'll start with 1 coil cut
  1. WTB coil overs or front drag struts
    Last Post: 01-24-2015, 01:14 AM
  2. Replies: 1
    Last Post: 03-14-2014, 11:42 PM
  3. Stock Fox front spring install
    By JOlbert in forum Fox-SN95
    Last Post: 11-12-2012, 04:33 AM
  4. Front Weld Drag Lites??Spacers needed??
    By lib88stang in forum General Tech
    Last Post: 10-12-2010, 11:26 AM
  5. Drag front suspension on the street.
    Last Post: 07-04-2007, 08:03 PM
