Results 1 to 4 of 4
Thread: Gauges question
    Senior Member RogerStout's Avatar
    Jan 2011
    Lumberport WV
    281
    Gauges question
    Just got my car yesterday so I have not really had time to tear into it just yet but I did notice the stock Oil Pressure and Water Temp gauges are not working. There are Oil Pressure and Water Temp gauges in the Pod that are but it bothers me they are just dead in the dash..
    The pod gauges are mechanical, are the stock gauges mechanical? Possible the just disconnected the stockers and ran the lines to the pod?
    94 GT
    I am a newb to the forum and mustangs too, if this is in the wrong forum I apologize Mods feel free to move it.
    Sep 2008
    72
    Sounds like they just disconnected the stockers. The mechanical oil pressure gauge would be ran from the block where the stock oil pressure sending unit would have been. You could devise a "t" type set up with common fittings and get a stock sending unit and run both if you want to. The temperature gauge would be the same way and the stock temp sending unit would have been removed to install the mechanical one. There are other spots in the intake to run the stock one by removing a plug (I think) but if you put it in another spot the temperatures will not match exactly between the two gauges due to the different locations of the sending units. Somebody correct me if I'm wrong. By the way neither of the two stock gauges in the dash are mechanical.
    Adam
    2003 cobra---sold
    2002 gt MPH long block with stage 3 2V heads, MPH custom grind cams, Kenne Bell 2.8H with MPH behemoth inlet, return fuel system, Zex nitrous kit(75 shot), 6-speed, built 8.8, etc. --SOLD
    Jan 2011
    Lumberport WV
    281
    Thanks for the info.. Not that I needed them I just don't like dead gauges.
    Thanks again
    wvstreets.CO
    the whole stock guage cluster is electric
  1. gauges
    By punkbomb138 in forum Ford Vehicles
    Last Post: 07-17-2011, 05:59 PM
  2. SN 95 gauges?
    By pRojekt02GT in forum General Tech
    Last Post: 04-08-2009, 11:34 PM
  3. Gauges...
    Last Post: 03-26-2009, 01:52 PM
  4. New gauges
    By Mitternacht in forum Pictures & Videos
    Last Post: 11-30-2007, 06:51 AM
  5. Gauges
    Last Post: 05-24-2007, 03:07 PM
