Results 1 to 6 of 6
Thread: Ford 9" rear in a fox body
    Jul 2010
    North Huntingdon, PA
    438
    I have friends who are circle track racers and I hear often about how strong and easy to work with the Ford 9" rear end is. I've looked into it and there are companies that make 9" rears with the correct brackets to fit under a fox body ( Moser and Strange both come to mind but I'm pretty sure there were a couple others ). My question is - if it's such a good rear end, why don't I see it done much with foxes ? Is it the expense that is more of a deterrent or is it that the 9" rear is not that much stronger than a nicely built 8.8 rear ?
    We have put over 1,000 horse thru an 8.8. When properly built they can take some serious power.
    2011 Mustang GT Kona blue
    2002 F-150 FX4 true blue, with Lightning blower swap
    2004 F-150 FX4 forged bottom end, built trans, Street Lethal Performance 76mm turbo kit, Black, Gray Leather, 6"susp, 3"body on 37's
    Let us know your parts needs we will work to beat any price!
    (724)964-8419
    9am-5pm M-F
    In house chassis dyno
    never stock biminiLX's Avatar
    Beaver
    2,406
    8.8 is lighter and more efficient and has been in the 7s when built for about the same price as a 9".
    The 9" with an Aluminum centersection is the same weight, advantages are easier gear swaps, more parts available, can be built stronger for extreme use.
    You answered your own question basically, most Mustangs already have an 8.8 and it can be built up for about the same price.
    I was at a point that if I broke one more 8.8 I was going to a 9". I got the right combo of parts now that it seems to hold up well enough. As was said, doing the conversion is what really kept me from doing it. I build a 8.8 with everythig that could be done to one for about what the 9" housing costs (Fab 9) or for what a good 9" chunk goes for (Aluminum carrier, differential, gears, etc).
    Mar 2009
    796
    A chassis builder told me because the 9" has a larger diameter center section than the
    8.8, the upper control arms have to be slightly relocated and that can negatively effect
    the suspension geometry or articulation. It's probably not an issue with a drag race car
    but could be an issue with a dual purpose street / strip car.
    Beaver
    2,406
    This is true, but some designs like the Team Z Strange 9" housing have mounting points modified to keep the Fox suspension geometry.
  1. Fox body 5 lug rear conversion $80
    By oldfox in forum Ford Vehicles
    Last Post: 09-24-2009, 02:31 PM
  2. 8" ford rear
    By 71mach in forum Ford Vehicles
    Last Post: 09-02-2009, 09:42 PM
  3. fox body rear end
    By 85stang in forum Fox-SN95
    Last Post: 01-24-2008, 08:11 AM
  4. Wanted 79-93 Bolt In 9" Rear Fox Body
    Last Post: 08-21-2007, 11:21 AM
  5. Fox Body Rear control arms and tq boxes
    Last Post: 12-03-2006, 12:43 PM
