Results 1 to 3 of 3
Thread: belt depth differences on a Fox 5.0 and a 94 95 SN95 5.0
    Senior Member oldfox's Avatar
    May 2009
    296
    Hi Guys,
    I know that the 86-93 and 94 95 5.0 engines have the belts a different
    depths but witch one sits farthest away from the block?
    I'm thinking of getting a different supercharger for the Fox and
    I was wondering if I ever get a 94 or 95 if I could just shim the lower
    pulley out.
    Senior Member TJH64's Avatar
    Delmont PA
    320
    The sn95 has the pulleys situated closer to the block, how much, I am not sure.
    May 2009
    296
    nuts I was hopping it was the other way.
    But thanks for the info
  1. Sn95 t5 for fox t5
    By blk93notch in forum Ford Vehicles
    Last Post: 08-03-2013, 07:28 PM
  2. Fox Mustang seat differences (vert)
    Last Post: 03-23-2012, 11:08 PM
  3. Bell Housing depth
    Last Post: 11-13-2010, 09:45 AM
  4. Replies: 1
    Last Post: 12-20-2009, 03:14 PM
  5. Short Belt FOX
    Last Post: 04-15-2007, 03:53 PM
