Hi before I buy a sump and have it installed on my tank I thought I would check and see if anybody might have a used one.
Also I was going to go with a Holley blue pump and a decent filter
But I'm open what do you got?
I bought a new stock tank and a sump from competition engeering and welded it in. The sump needed alittle work to work on the tank. I'm running a Weldon 1100a pump with there pre and post filter 10an out. And I returned into the top of the tank where the stock pump was. I just cut a piece of 1/8in steel and used a bulkhead fitting.
For as easy as it is to do and costly as a tank from aeromotive is, doing your own wins. But then again I like to do most of my own stuff.
427w, afr225, ci hyd roller, super vic, single stage, and swapped aode to tko600 to PA c4 w/brake.
605rwhp 700rwtq
MMFF june 09 feature car http://www.musclemustangfastfords.co...ker/index.html
i have a stock tank that was only in my car 2 months, also have a granatelli pickup.
here is a link to it
http://www.summitracing.com/parts/GRN-GM-TI7998/
