Results 1 to 11 of 11
Thread: need some help with timing please
    I can't get the timing on my 5.0 can someone explain what I need do do from the beginning. Thanks
    Big member venom's Avatar
    North Fayette Township, PA
    1,344
    I copied this from another site:
    TDC (top dead center) on the COMPRESSION stroke.
    put the dizzy in and rotate the base until it is on the #1 spot on the cap. then pull the spout connector, tighten down the dizzy enough that it wont spin freely but u can make it twist, then fire it up, aim timing light at pointer, rotate dizzy until the pointer is at 10 (clockwise=advance) then kill it, put spout in, tighten down dizzy and you are good to go
    2015 GTPP
    Easiest way to find compression stroke is pull out number 1 plug and plug the hole with your finger. When the comression pushes your finger away you know you are coming up on the comp stroke.
    Exactly. Then rotate the crank by hand and drip in the dizzy. Noting where number 1 is on the cap. Use a sharpie and put a dot on the housing so you can get the rotor pointing there. Then when it runs pull the spout out and set timing to 14° if you are staying N/A.
    Oh yeah, you need to update your thread there too shorty!!!! I am sure some of the new guys would like to see what you made out of the klunker you bought. Its only been what, 3 years?
    1,344
    True. It's starting to look like a mustang now!!!
    2015 GTPP
    South Hills, PA
    4,052
    nothing wrong with taking a few years, lol
    Tim, Bill, Hahaha. Yeah, really!!!!
    Thanks guys it runs whoo hoo it feels good
    Well??????????
    Update your thread then
    We wanna see..
    Member silvernotch's Avatar
    Bethel Park
    664
    Now it runs get it done. you only have 5 months.
    1,344
    It's been three weeks, and the timing still isn't set on the car. Get off your ass man!!!
    2015 GTPP
  1. Timing Advance 94 5.0
    By J-rod in forum Fox-SN95
    Last Post: 05-18-2014, 12:48 PM
  2. timing help!
    By matty g in forum Fox-SN95
    Last Post: 03-05-2012, 07:15 AM
  3. need help timing motor
    Last Post: 06-05-2011, 11:49 AM
  4. 2.3 Turbo Timing HELP!!!!
    By fordandmopar21 in forum Fox-SN95
    Last Post: 12-04-2008, 03:03 PM
  5. Timing Problems, Help!!!!!!!
    By ArmyWarrant in forum Fox-SN95
    Last Post: 05-17-2008, 09:37 PM
