Results 1 to 3 of 3
Thread: Door hinge repair
    Cheap SOB
    Baltimore, Maryland 21236
    288
    Door hinge repair
    Okay I know I am being anal about this, but there is a tensioner plate on the lower door hinge that presses against a roller wheel. This is used to keep the door open when you open it. Most that I see seem to have the re-curved metal tab on the hinge broken. I was trying to bend the existing remains of the tab and it came off the hinge. It doesn’t seem to be permanently attached to the lower hinge. Do they make a replacement part for this? I am sick and tired of the door swinging back closed and catching my shin in the door jam.
    Thanks.
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    Have you talked to Lou at LMM?
    I have the same problem on my drivers doors. It should be replaceable. Mine snapped off completly.
    Mark Lowry
    Now's a good time to replace the door pins if you doors are loose too!
  1. a/c repair?
    By fast4ord in forum Other Makes / Models
    Last Post: 03-23-2014, 11:27 AM
  2. AC repair...anybody on here do it
    By torqueboxer in forum General Tech
    Last Post: 05-28-2009, 10:54 PM
  3. Door Hinge
    By coralcoupe1993 in forum General Tech
    Last Post: 12-02-2008, 06:32 PM
  4. Wanted: Driver's Side Door Hinge(s)
    Last Post: 05-25-2007, 04:41 PM
  5. T-5 Repair help
    Last Post: 03-12-2007, 08:11 PM
