Results 1 to 2 of 2
Thread: Basic air conditioning wiring question
    Senior Member oldfox's Avatar
    May 2009
    296
    Hi I have a question about air conditioning wiring
    I know that 12 volts comes from the switch in the dash and then runs through the pressure switch that shuts off the compressor if the 134a gets low then to the relay that sends the 12 volts to the compressor.
    But somethings missing here,, Isn't there a switch something like a thermostat in the evaporator core somewhere to shut the compressor off if it gets to cold to keep it from freezing up?
    Is it tied in on the negative side of the compressor magnet?
    or does that run straight to a ground?
    and How does it kick off and on when it's at an idle?
    I wish I could draw a schematic on here.
    May 2009
    296
    bump
  1. Wiring question help!!!
    By How Much? in forum The Bar
    Last Post: 02-01-2012, 10:52 PM
  2. Transmission wiring question
    By Darren in forum General Tech
    Last Post: 03-07-2011, 12:43 AM
  3. Replies: 15
    Last Post: 02-18-2011, 10:22 PM
  4. V-8 conversion wiring question
    By oldfox in forum General Tech
    Last Post: 11-14-2009, 03:18 AM
  5. WTB: Mass air wiring harness
    By blkp42e in forum Ford Parts
    Last Post: 10-01-2008, 05:22 PM
