Results 1 to 4 of 4
Thread: SN-95 5.0 rear main seal replacement
    Member Warrior1670's Avatar
    Oct 2010
    Cranberry Township, Pa
    97
    Exclamation SN-95 5.0 rear main seal replacement
    OK, so it's time to replace the rear main seal. How much PITA can I expect? Pull the h-pipe, tranny, clutch...anything else? Any special tools I should need?
    Any other (.........let's call them "repairs" so my checkbook doesn't get mad if I call them "upgrades") that should be done? New clutch is already in there.
    Anyone here wanna do it for a nominal fee (less than a dealer hopefully)?
    Replace the pilot and throw-out bearing while you are in there. The pilot bearing can be a PITA to get out, I've had luck with the old grease trick. The rear main can sometimes be a pain to remove and reinstall uniformly, but with a little patients it is not hard. I have to do mine again too. this will make like 6 or 7 that I've done. Don't waste your money on the teflon lined rear main seal from fel-pro, it leaks just as much as the normal cheaper one.
    Oct 2010
    97
    I just got the ford racing seal from LMR. Does the pilot bearing need replaced? My throwout bearing is making quite a racket and it's on the list as an actual needed repair, I didn't think about the pilot.
    How much time do you think this will take? 4-6 hours? days? weeks?
    Senior Member cobra tom's Avatar
    Dec 2010
    in my house
    106
    if you are on a hoist it should be around 3 hours, on the ground will be much more.
    working on the shelby
  1. Rear main seal replacement 03 Cobra
    By Terminated in forum SN95-New Edge
    Last Post: 02-01-2012, 01:49 PM
  2. Main Seal Replacement #1
    Last Post: 05-18-2011, 09:26 AM
  3. rear main seal questions???
    By White5.0 in forum Fox-SN95
    Last Post: 06-18-2010, 01:14 PM
  4. Rear Main Seal 04 Cobra
    By burntire in forum SN95-New Edge
    Last Post: 01-26-2009, 07:46 PM
  5. It is never simple, which rear main seal?
    By DRRummel in forum Fox-SN95
    Last Post: 11-21-2008, 10:36 AM
