Results 1 to 7 of 7
Thread: exhaust help
    Member 84QuadEye's Avatar
    Feb 2011
    Ligonier, PA
    28
    exhaust help
    ok so i have been searching for a exhaust for my 84 hatch....now is there a reason why all the exhaust companies only go down to 86 and would the 86 exhaust fit on my 84 or do i got to build something custom..plz help
    South Hills, PA
    4,052
    Welcome...
    A couple of reasons, some good, some not so much.
    Most manufacturers think the fox body Mustang started with the aero cars.
    The early cars did not have the double hump crossmember needed for dual.
    The four eye cars that came with single exhaust do not have provisions for the hangers on the passenger side.
    There where variations at the header / manifold connection point on early cars (heat risers).
    Some cars have a fuel pump where the passenger muffler needs to go.
    Likely a few others I'm missing. All of this can be overcome, just need to work through details.
    Feb 2011
    Ligonier, PA
    28
    ok so basically i can buy an exhaust for an 86 i am just goin to need to put hangers in were they need to go or would the easier route be just to run some dumps
    Quote Originally Posted by 84QuadEye View Post
    All that dumps will save you is the one hangar below the quarter for the tail pipe. You will still need ot deal with the headers, cross member, and hangars to the mufflers. Might as well add one more hangar at that point and not live with dumps.
    I have a Flowmaster cat back thats going back up for sale.
    I'm pretty sure I have a double hump crossmember lying around...cheap!!
  1. 5.0 exhaust, which is better h or x?
    By PSPstang in forum Fox-SN95
    Last Post: 10-20-2012, 09:35 AM
  2. exhaust?
    Last Post: 03-21-2012, 07:01 PM
  3. exhaust
    By fryer19 in forum Ford Parts
    Last Post: 05-06-2010, 07:40 AM
  4. New Exhaust!!!!
    By Rio94gt in forum S197
    Last Post: 10-29-2007, 09:07 PM
  5. New Exhaust Now On!!!!!!!!!
    By PunisherStang in forum S197
    Last Post: 10-12-2007, 11:06 PM
