Results 1 to 12 of 12
Thread: Gear brand question..
    Dec 2010
    167
    Hello I wanted to know if Motive gear was good brand name gear for my car?
    I am going to be going with 4.30s for my cobra.
    We have installed motive and a ton of ford racing gear sets. They both work well but I would reccomend ford racing gears.
    2011 Mustang GT Kona blue
    2002 F-150 FX4 true blue, with Lightning blower swap
    2004 F-150 FX4 forged bottom end, built trans, Street Lethal Performance 76mm turbo kit, Black, Gray Leather, 6"susp, 3"body on 37's
    Let us know your parts needs we will work to beat any price!
    (724)964-8419
    9am-5pm M-F
    In house chassis dyno
    Go with ford gears, the installer will thank you.
    Under PSI Black Vert's Avatar
    Cranberry Twp.
    344
    Ford gears x3
    89 Vert, Stock block, H/C/I , DIY turbo kit MPT70 , Tweecer RT, C4 trans. 17 lbs boost. 3400#s - 10.3 @ 136 mph.
    Dyno Jet - 542 RWHP / 545 RWTQ
    Mt Pleasant
    2,916
    FMS or OEM
    Dec 2010
    167
    Quote Originally Posted by StreetLethal View Post
    why is that?
    and whats the down side of motive?
    Quote Originally Posted by Killercanary View Post
    Exactly. So will the pocket when there isnt hours of extra instal time.
    Going fast with class Slow01GT's Avatar
    Mars, PA
    1,696
    Quote Originally Posted by Black cobra View Post
    why is that?
    The Ford gears tend to install with less shimming which means you will spend less on install time. The steeper motive gears like the 4.10's and 4.30' s also seem to make noise even when set up correctly. Save yourself some hassle and spend a little more on the FRPP gears
    Dennis
    2006 GTO
    Gone but not forgotten
    2015 SHO
    Mostly stock
    2014 Cruze
    Living the MPG life
    Ford racing
    Dec 2010
    167
    Okay thanks guys!
    We charge the same no matter what gear set is installed. The ford gears set up alittle easier but we have not had any issue with motive gears making noise either. You just have to be right on with the pinion depth.
    Dec 2010
    167
    Okay, Great Thank you!
    I will be calling you soon!
  1. 2010 GT gear question
    By Darren in forum S197
    Last Post: 06-23-2012, 02:57 AM
  2. Gear Brand
    By coralcoupe1993 in forum The Bar
    Last Post: 10-24-2008, 01:41 PM
  3. Gear Question?
    By mineralrob in forum General Tech
    Last Post: 07-11-2008, 10:01 PM
  4. Exhaust and gear question
    By Inkdcountryboy in forum General Tech
    Last Post: 04-22-2008, 09:47 PM
  5. Gear question
    By Cam99 in forum Fox-SN95
    Last Post: 04-22-2007, 11:01 AM
