Results 1 to 8 of 8
Thread: Steering rack help
    adult daycare speedracer's Avatar
    Somerset Co.
    2,907
    Steering rack help
    I just put lowering springs, swaybars, CC plates and Steeda bumpsteer tie rod ends on my Cobra. After I got the car on the ground I turned the key to on (not running) and quickly worked the steering wheel back and forth and I could hear and feel a clunk in the front end.
    I had a friend stop and work the wheel while I tried to figure out where it was comming from. It seems to be comming from the drivers side of the rack where the inner tie rod screws into the piece that slides through the rack. I can take a screwdriver and move that piece up and down a little bit.... I'm going to assume thats not normal. I haven't taken the boot off the other side to see if it does it on that end.
    The car has 30,014 miles on, I would have thought the rack should have lasted 4 times that many miles.
    Senior Member blizzard's Avatar
    Mar 2008
    Castle Shannon
    1,276
    just a guess, you UNscrewed the tierod while putting on your bumpsteer kit ?? which btw, should be parallel with the A-arm at load.. ;)
    SCS Founder Sonic03snake's Avatar
    Mt Pleasant, PA
    4,905
    These cars are notorious for bad racks. Its probably nothing you did, just found it by chance.
    Lou
    Best non ported stock pullied eaton pass
    1.50 60ft 11.160@ 125.08
    New combo,
    Ported Eaton, upper/lower
    508 Hp 548 TQ SAE on an inferior Dynojet Dyno
    1.43 60 ft. 10.55 @ 130 MPH
    WFC 8 Mod Motor Winner
    06 NMRA Martin, Mi. Mod Muscle Winner
    Somerset Co.
    2,907
    Quote Originally Posted by blizzard View Post
    They are... the picture makes them look a little off.
    This pic is at a better angle
    Somerset Co.
    2,907
    Quote Originally Posted by Sonic03snake View Post
    I've been searching and found a few others that have had bad racks... Not sure if i'm going to get a new or re-man
    Mar 2008
    Castle Shannon
    1,276
    Quote Originally Posted by speedracer View Post
    ah ok..
    Senior Member 97LaserRed's Avatar
    Jan 2008
    Jefferson
    4,674
    Prob just need a new inner tierod. I'm sure it has play in it when you shake back and forth at the tire. They are simple to change. Like stated before. Prob just unscrewed the inner when installing the bumpsteer. Use loctite when installing a new one.
    Somerset Co.
    2,907
    Quote Originally Posted by 97LaserRed View Post
    No play in the inner tie-rod... it will turn forever without unscrewing from the rack (ball and socket end) the slop is clearly in the section that the inner tie-rod screws into.
  1. reman steering rack
    By bittersweetfox in forum Ford Vehicles
    Last Post: 05-21-2013, 07:13 PM
  2. Steering Rack Help
    By sinful rides in forum General Tech
    Last Post: 03-22-2011, 08:56 AM
  3. Manual steering rack
    Last Post: 12-16-2010, 11:59 PM
  4. Steering rack box
    By cwh19 in forum The Bar
    Last Post: 01-06-2010, 12:15 AM
  5. Steering rack width
    By blizzard in forum General Tech
    Last Post: 09-05-2008, 06:35 AM
