Results 1 to 10 of 10
Thread: which oil pan,pump for my 408w?
    Member 1badnotch's Avatar
    Northern Cambria,PA
    1,366
    I need an oil pan for my sportsman block 408w in my '91 notch. What brand(moroso,canton,etc)should I go with and why? I am also up in the air on an oil pump for it. Should I run an ARP oil pump shaft? Any suggestions welcome. Thanks.
    Mark
    never stock biminiLX's Avatar
    Beaver
    2,406
    Hey Mark, used to run a Canton Pro pan, now run a custom Stef's I got a killer deal on, both have worked well no problems. You will have it easier than a Dart Iron Eagle with 4-bolts on all mains, my SVO is like your Sportsman and more selection available.
    I run an ARP shaft and Melling pump.
    grudge king X-CELL RACING's Avatar
    Jan 2011
    draggin u 1320ft at a time
    86
    Mark I recommend using a moroso MOR20520 oil pan a melling m-83 oil pump and a ford racing. A341* shaft. This is a bullet proof setup plus its worth a little power too. The only better setup is a bilet fab pan and peterson external wetsump oil pump.
    Northern Cambria,PA
    1,366
    pan/pump
    Thanks for the replies fellas. I will have to do some searching around for prices and such. So I only need a standard volume oil pump,not a HV pump? I will be running a turbo soon.
    I am glad that I went with the sportsman too. Like you said J,a lot more choices.
    Jan 2011
    86
    When I ran twin 76mm I only ran a standard volume pump all I did was shimmed the releaf spring a little
    Northern Cambria,PA
    1,366
    pump
    Cool. I just wanted to be sure. Thanks.
    Jan 2011
    86
    Yep no prob
    Northern Cambria,PA
    1,366
    pan/pump
    After doing some checking I think that I have made up my mind. I am going to order a canton pro pan,melling M-83 pump and A341 ford racing shaft. Thanks for the advice fellas.
    Beaver
    2,406
    Is that standard or high volume?
    I think you'd be fine either way, I went HV based on recommendation at that time with a a turbo system.
    Northern Cambria,PA
    1,366
    oil system
    Well I changed my mind again,LOL. I just ordered a moroso eliminator oil pan #20532,moroso pick up tube #24532,ARP oil pump shaft and melling M-83HV pump modified with a screw adjuster to adjust the pressure(from Holcomb Motorsports). The oiling system is done!
  1. WTB 96-04 4.6 oil pan
    By SK@StreetLethal in forum Ford Parts
    Last Post: 04-09-2012, 11:20 PM
  2. 95 GT Oil Pan Leaking
    By 95DropTop in forum Fox-SN95
    Last Post: 05-04-2011, 09:01 PM
  3. Replies: 7
    Last Post: 05-01-2010, 08:59 PM
  4. Oil pan refinishing
    By PSPstang in forum General Tech
    Last Post: 02-10-2008, 08:51 PM
