I need an oil pan for my sportsman block 408w in my '91 notch. What brand(moroso,canton,etc)should I go with and why? I am also up in the air on an oil pump for it. Should I run an ARP oil pump shaft? Any suggestions welcome. Thanks.
Mark
Mark
2013 Mustang GT,ingot silver,black leather,MT82,track pack,Kooks headers/x-pipe,GT500 OA pipes,Roush mufflers.
2002 F250 Lariat,dark shadow gray,gray leather,CCSB,4x4,7.3 diesel,auto,lots of mods.
2017 Explorer XLT,canyon ridge,black cloth,AWD,2.3 Ecoboost,K&N filter
2010 Flex Limited,ingot silver,black leather,AWD,3.5 Ecoboost,AFE filter,HD brakes
2014 Honda Pioneer 700-4,'89 Yamaha Blaster
Kubota B7800,30hp diesel,AG tires,front loader,box blade
Hey Mark, used to run a Canton Pro pan, now run a custom Stef's I got a killer deal on, both have worked well no problems. You will have it easier than a Dart Iron Eagle with 4-bolts on all mains, my SVO is like your Sportsman and more selection available.
I run an ARP shaft and Melling pump.
Mark I recommend using a moroso MOR20520 oil pan a melling m-83 oil pump and a ford racing. A341* shaft. This is a bullet proof setup plus its worth a little power too. The only better setup is a bilet fab pan and peterson external wetsump oil pump.
Thanks for the replies fellas. I will have to do some searching around for prices and such. So I only need a standard volume oil pump,not a HV pump? I will be running a turbo soon.
I am glad that I went with the sportsman too. Like you said J,a lot more choices.
When I ran twin 76mm I only ran a standard volume pump all I did was shimmed the releaf spring a little
Cool. I just wanted to be sure. Thanks.
After doing some checking I think that I have made up my mind. I am going to order a canton pro pan,melling M-83 pump and A341 ford racing shaft. Thanks for the advice fellas.
Is that standard or high volume?
I think you'd be fine either way, I went HV based on recommendation at that time with a a turbo system.
Well I changed my mind again,LOL. I just ordered a moroso eliminator oil pan #20532,moroso pick up tube #24532,ARP oil pump shaft and melling M-83HV pump modified with a screw adjuster to adjust the pressure(from Holcomb Motorsports). The oiling system is done!
