Results 1 to 5 of 5
Thread: Battery Light?
    Feb 2011
    Kittanning
    45
    Battery Light?
    I was just wondering if anyone knew what could cause the battery light to turn on when a certain RPM is hit. While driving i have noticed that around 3000-4000 rpm the battery light will turn on. When i asked to have battery checked at Autozone they said it was probably the tensioner spring. Anybody got any ideas to help me out?
    Yeah - could be your serpentine belt is slipping due to a bad tensioner.
    If that is it, I bet some folks around here might have one lying around.
    Member badstanglx's Avatar
    altoona
    676
    is the belt lose and check and see if u can spend the alt by hand if so u need tighten the belt!!!!
    Feb 2011
    Kittanning
    45
    I will have to check that when it stops raining and im not at work... which is hard considering i work almost 16 hours every day. but i think it is there is a sound that makes me think its loose..
    Senior Member White5.0's Avatar
    State College, PA
    3,552
    it could possibly be the belt slipping, however...this happend to me...once i got up in the RPMs my battery light started going on then when the RPMs would drop it would turn off. eventually it started happening at lower and lower RPMs until it did it at idle. Turned out to be the alternator. they tend to do this when they start going bad. Go get your alt tested
  1. Battery recommendations
    By Killercanary in forum The Bar
    Last Post: 03-13-2011, 03:22 PM
  2. Battery Shut Off
    By Stangman701 in forum Drag Racing
    Last Post: 09-02-2010, 04:46 PM
  3. battery
    By hunter31 in forum SN95-New Edge
    Last Post: 03-05-2009, 10:32 PM
  4. spark from battery!!!
    By 92306gt in forum General Tech
    Last Post: 02-09-2008, 05:51 PM
  5. Battery on/off switch
    By coralcoupe1993 in forum Fox-SN95
    Last Post: 04-25-2007, 09:40 AM
