Hi, I have a 91 fox and I have SN-95 (1995) disc brakes all the way around. Now I'm getting ready to install the booster and master cylinder from a SN-95 also. Rather than use the 2-to-3 kit I'm going to use a line lock to split the front line into two lines. I called maximum motorsports and the have a conversion line kit for the older fox 85-back mustang that should work it's two lines that go from the SN-95 master cylinder to the Fox stock proportioning valve. From there I was going to run the line for the front brakes into a line lock. The line lock has two out lets so I figured that I use the two outlet lines for the front brakes. Sound like that would work? If your running a line lock I don't see any other easy to do it.
Note: I'm going to gut the proportioning valve and install manual valve on the firewall.
Thoughts?
