Results 1 to 7 of 7
Thread: 91 gt build
    cruisin for a bruisin geps91stang's Avatar
    Aug 2010
    connellsville
    160
    91 gt build
    hi guys i've been throwing around the idea of mildly building my 91 gt here are some of the things i've been thinking about doing
    1.rebuilding the engine new rings bearing gaskets ect.
    2.going with an e303 cam stock heads and cobra upper/lower
    3.set of 4.10 gears ( have a stock aod not sure how that will work out)
    4.#24lb injectors and matching maf
    just wondering what you guys thinks i don't have a race car and it wont be seeing the track it's a street car just want to increase power and low end torque for tearin up the streets thanks everyone
    You dont need the 24# injectors at that power level.
    1969 Camaro restomod/project
    1967 camaro
    2011 mustang procharged
    93 reef blue notch blk/int
    92 calypso notch blk/int
    86 t-type
    1972 chevelle project
    Not only did I fail at building a fast mustang but I bought a yellow zo6 cause I couldn't get my little dick up.
    never stock biminiLX's Avatar
    Beaver
    2,406
    I think the 24# isn't a bad idea if you're buying a meter.
    Don't put any money into the stock heads, not worth it with the Alum. stuff out there affordable.
    What about finding a lower-mile 5.0 from the last 302 Explorers/Mountaineers, you get GT40 heads/Cobra like intake?
    -J
    '91 LX Bimini Blue
    427"/88mm on 16psi
    '99 Contour SVT
    Clean DD
    Senior Member frankstang's Avatar
    Sep 2007
    Homestead
    780
    I liked the AOD and 4:10's when I ran them. If you have plans on converting to a 5 speed down the road though, I'd go with a 3:55 or 3:73 instead.
    If you're keeping the E7 heads I'd stay with 19# injectors but ditch the old OE injectors and pick up a set of the Bosch Design III 19's. They're all over Ebay for $100 and under.
    http://cgi.ebay.com/ebaymotors/BOSCH...Q5fAccessories
    Try to get an OE Cobra intake or an Explorer as the newer FRPP China made Cobra intakes have had some quality problems.
    Aug 2010
    connellsville
    160
    will my stock plumbing and fuel rails work with the explorer or cobra intakes also someone told me that if i go with the e303 cam i would need to change the valve springs to prevent collapsing a valve not sure how true this is either
    Aug 2010
    connellsville
    160
    here is what a guy told me from another mustang site it sounds like what bimini said about the gt40 heads/intake i'm not sure about the 94-95 maf though
    If you haven't bought any parts yet don't. Do yourself a favor and get an explorer top end. It has the same heads/intake as a cobra and it comes with a 65mm tb. Use your 19lb injectors and get a 94-95gt maf. Unless you already have the e cam laying around don't waste your time. The stock cam is a great piece, but if you want a good budget oriented ots cam the tfs1 is at the top of the list. Either way you have no business replacing the cam if you haven't upgraded the heads yet. The combo I just listed I have personally pieced together for less than 500 dollars and will give a solid 30-40hp more than what you have listed.
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    Basically the same combo-cam (I had P's, explorer intake, and an AFM N41 cam) went 12.40s on drag radials in my 86GT. Good combo. I would spring for a better mass air sensor, but just my opinion. Seeing that restriction in the intake tract just makes my head hurt.
    2014 Mustang GT Stock and for sale
    2014 M235i (wife's)
    1964 Ford F-100
  1. New Cobra Build
    By Stangman701 in forum SN95-New Edge
    Last Post: 06-20-2012, 09:38 AM
  2. Build AOD vs. Build C4
    By roush08 in forum Fox-SN95
    Last Post: 01-27-2011, 08:13 AM
  3. my 73 highboy build
    By turbo83coupe in forum General Tech
    Last Post: 01-02-2011, 10:57 AM
  4. I have got to build one of these
    By Martin0660 in forum Pictures & Videos
    Last Post: 06-12-2009, 11:07 PM
  5. Which is better and cheaper to build?
    By scott5 in forum Fox-SN95
    Last Post: 01-25-2008, 06:49 AM
