Thread: 15x9 5.5bs rear wheel on fox
    TELL IT LIKE IT IS crazylou's Avatar
    Nov 2008
    ELIZABETH TWP.
    885
    Question 15x9 5.5bs rear wheel on fox
    Ok will a 15x9 5.5 b.s. wheel stick out past the fender on a fox?????
    -does any1 have pics of a 15x9 5.5 b.s. on a foxbody if so can u please post a pic of ur ride...
    -tire size im runnin 275-50-15, 60 series pic will work also...
    Thank you...
    COREY...
    *04 Torch Red Cobra
    1 of 164 with med.graphite inserts
    Work done and Tuned by Rodeheaver's Hot Rod shop...
    471hp/489tq
    *1970 chevelle ss L-S5 454, 4 spd
    real deal not a clone have paperwork
    Under PSI Black Vert's Avatar
    Cranberry Twp.
    344
    An 8 inch wheel 5.5 back space.
    10 inch wheel 6.5 back space.
    So I would guess with a 9 inch wheel you would want to use 6.0 back spacing.
    I run a 10 inch with 6.5 bs. with a 275/50r15 MT DR.
    Attached Images Attached Images
    89 Vert, Stock block, H/C/I , DIY turbo kit MPT70 , Tweecer RT, C4 trans. 17 lbs boost. 3400#s - 10.3 @ 136 mph.
    Dyno Jet - 542 RWHP / 545 RWTQ
    Pinks All Out #189 349Stroker's Avatar
    Petersburg,PA. 16669
    816
    Quote Originally Posted by crazylou View Post
    Thank you...
    it will fit perfect...have ran them before, it wont stick out. it will fit just like the 10" wheel above. only difference in the 10 and the 9 is the 1" of backspace
    88 GT...and some boost
    Nov 2008
    ELIZABETH TWP.
    885
    ok thank you..
    COREY...
    *04 Torch Red Cobra
    471hp/489tq
  1. convert rear wheel hp to flywheel hp
    By 94REDGT in forum The Bar
    Last Post: 08-30-2011, 04:18 PM
  2. 2 15x8 4.5bs draglites
    By dyhar1 in forum Ford Vehicles
    Last Post: 01-16-2011, 07:14 PM
  3. Rear Drag Wheel PKG
    By mr4teth in forum Ford Vehicles
    Last Post: 09-08-2009, 10:09 PM
  4. (2) 15x9 Weld Pro Stars
    By 349Stroker in forum Ford Vehicles
    Last Post: 05-24-2009, 11:46 AM
  5. Max. rear tire / wheel size
    By gmslayer in forum General Tech
    Last Post: 12-20-2008, 11:35 PM
