Results 1 to 13 of 13
Thread: auto tranny question
    charleroi
    478
    Hey fellas im kinda new to scs so point me in the right direction if im in the wrong forum or somthing. Im building a 1994 mustang 5.0 turbo car should b 550 600 rwhp and want to do a c-4 swap. I was thinking of buying a ptc tranny and converter has anyone had any experience with there trannys good bad or otherwise? Any
    advice would b appreciated.
    charleroi
    478
    anybody??
    Under PSI Black Vert's Avatar
    Cranberry Twp.
    344
    I dont have any experience with PTC but Ive heard good things about their converters. I would recommend getting a C4 with a trans brake if you plan on taking it to the track.
    Leechburgistain Mainland,Cuba
    1,534
    289 slabside cobra
    6S1941
    never stock biminiLX's Avatar
    Beaver
    2,406
    I've got a 5.0 turbo too but that means a lot different things to different people;)
    how much power we talking and what do you plan on doing with it--street, strip, both?
    I switched from a TKO to an auto and decided to go with a built AOD for what I want to do with the car. My brother uses a PA Super Comp C4 with good results also.
    Powerglide, Turbo 400, AOD/4r70W, C4 are probably the best auto choices and which one depends on your goals.
    charleroi
    478
    Well it will be street strip but im more concerned with how it does at the track b/c it will probally see very few street miles. Im hoping to b right at the 550ish hp mark. Edelbrock heads f cam torkerII intake and a masterpower 67 all on a stock bottom end. I talked to the guys at ptc and they said there trans brake c-4 is set up the same as the pa 6pinion planet 6 clutch high gear etc etc accept it dosnt come with a lifetime waranty. What kind of power does your brother make? and how is the pa holding up for him?
    Beaver
    2,406
    Quote Originally Posted by black 94 View Post
    He runs low to mid 10s been in for 4 years now with only fluid changes.
    I would say C4 for your goals should be perfect.
    Honestly with the turbo you will probably only want a 3.27 gear 3.55 max for that combo, so even street driving not bad.
    Sounds like a fun set-up good luck.
    South Hills, PA
    4,052
    i'd get your self a good block and forged bottom before you worry about a trans. block will split before you brake a built trans.
    Cranberry Twp.
    344
    I've been hearing that for 5 years now, I keep RPM below 6k and a safe tune, no cracks here. Maybe this year I'll break it , going for 9s
    Cranberry Twp.
    344
    Why not a MP 70 or 76?
    South Hills, PA
    4,052
    Quote Originally Posted by Black Vert View Post
    you one of them lucky guys out there, not many guys make it that long, congrats
    Cranberry Twp.
    344
    I've been around Mustang 5.0s for 20+ years, never seen one cracked in person. I've blown plenty of head gaskets. Seen pictures on the web of cracked blocks, so I know its possible. Maybe I need to push it harder and break it so I can go ahead and build the 351W I have sitting on the engine stand. :D
    charleroi
    478
    Went with the 67 figured it would spool fast and when i out grow it it be time for a new bottom end and block. Plus i talked with brian at bg turbo and he seemed to think that was a good size I dono i guess we will see?
  1. 97 GT auto o.d.tranny..$100.00
    By goose in forum Ford Vehicles
    Last Post: 06-15-2010, 01:46 AM
  2. Lot of Auto Tranny Questions
    By 02pnygt in forum SN95-New Edge
    Last Post: 03-13-2009, 04:24 PM
  3. 1989 2.3 motor and auto tranny
    Last Post: 11-22-2008, 04:33 PM
  4. Auto Tranny
    Last Post: 06-17-2008, 04:06 PM
  5. ideas on building auto tranny>>>?
    By PunisherStang in forum S197
    Last Post: 04-13-2008, 08:47 PM
