Results 1 to 3 of 3
Thread: Fox Oil Pan Gasket Question
    I need to put a new pan gasket on my fox. Anyone ever try to do this without lifting the motor? Just wondering if it's possible because I don't have an engine lift. Looks like it might be possible with some creativity.
    Belle Vernon
    1,294
    If you are changing it because it is leaking then I would say not to like that becuase you will probably end up with a leak again. You will probably have a hard time in the front and back over the humps.
    '89 Mustang GT
    '04.5 Duramax
    Jones Race Car Trailers
    www.jonesrv.com
    Mt Pleasant, PA
    4,905
    Ive done it twice but would not reccomend it, more work than its worth.
  1. Fox 351W solid mounts and oil pan
    By Dan B. in forum Ford Vehicles
    Last Post: 01-13-2013, 08:15 AM
  2. Leaky Fox oil pan
    By Dan B. in forum Fox-SN95
    Last Post: 08-11-2010, 12:12 PM
  3. Replies: 7
    Last Post: 05-01-2010, 08:59 PM
  4. 79-93 fox 351w moroso oil pan 4-sale
    By Rodeheaver's in forum Ford Vehicles
    Last Post: 09-05-2006, 10:25 AM
