Results 1 to 8 of 8
Thread: Fox body fuel line question
    State College, PA
    3,552
    Is it possible to use any kind of universal braided fuel lines to replace the hard lines that run along the passenger side of the car from the fuel tank to the engine bay? If so, what lines and what about the rubber lines connecting both hard lines? Would those adapt to aftermarket braided lines or what?
    2013 Mustang GT
    1999 Contour SVT
    Sep 2007
    Homestead
    780
    Russell makes a set of braided lines for 5.0's. Part #651104.
    Here's a pic.
    [IMG]
    State College, PA
    3,552
    Quote Originally Posted by frankstang View Post
    Here's a pic.
    Im looking for braided ones like that but not the ones that go from the fuel rail down to the rubber line with female connector....
    Im talkin about the ones that run along the passenger side of the car from the tank to the engine bay that have the rubber lines on the end that the ones in your pic plug into
    2013 Mustang GT
    1999 Contour SVT
    Senior Member oldfox's Avatar
    May 2009
    296
    well you could use brake lines and compression fitting I guess
    But that's not braided line SO,,, Yes you could run braided lines with hold down clamps to keep them in place and use a smaller line for the return with the right fittings no one that I know of makes a kit but I have bought some na lines and fittings from a place that might be able to hook you up if you like would you like me find out how to contact them and let you know? That NA stuff is not cheap --I just bought a bunch for my conversion OUCH And NO on the rubber hose and clamps bad idea on high pressure lines.
    look at the post above looks like russel makes the correct ends for what your doing
    Frankstan: Thats some nice stuff
    Oct 2010
    300
    I have braided fuel line on my notch just did it when I changed it to fuel injection I have like 250 in all of it even the an fittings
    May 2009
    296
    Quote Originally Posted by bluenotch View Post
    $250 that's a good price is that for both lines front to rear and all the fitings? (did better than me) but I'm runing a sump and I think 8 and 6 an
    isn't 8 and 6 like about 1/2 and 3/8?
    I have the adaptors to go where you are talking about and run braided to a set of aftermarket rails. Brand new never used. -8 feed and -6 return. If interested, PM me as I dont get on here much right now...
    State College, PA
    3,552
    thanks for the help everyone....i was asking this question for my father but he ended up just buying new ones anyways so i guess this thread can be closed
    2013 Mustang GT
    1999 Contour SVT
  1. Fox body speed sensor question
    Last Post: 06-03-2013, 10:55 PM
  2. Debadging fox body question
    Last Post: 01-06-2008, 02:37 PM
  3. fox body spring question
    By PSPstang in forum Fox-SN95
    Last Post: 10-31-2007, 07:52 PM
  4. Wanted Fox Body EFI Fuel Tank- clean
    By wht88cpe in forum Ford Parts
    Last Post: 04-02-2007, 12:55 AM
  5. Fuel question FOX
    Last Post: 12-26-2006, 12:45 AM
