Sold!!!
I am thinking of selling my 2002 laser red mustang GT. I just don't have time for it anymore. Car has 72,600 miles. Motor has about 12.5k miles. Blower has about 7k miles. Car runs and looks excellent. The air conditioning blows ice cold. It makes 669 rwhp on 93 octane and 742rwhp @ 23psi on C16. There is currently no tune for the nitrous but it is hooked up and functional. I just never see a need for it but the bottle is full and the purge looks pretty cool. There is obviously a lot of money invested here but I am also realistic when it comes to the price...that is why I set the price at $16,500 which I think is fair for the extensive mods which are as follows:
ENGINE:
Modular Powerhouse built short block (281ci)
Modular Powerhouse stage 3 race 2V heads
Modular Powerhouse custom grind cams
Canton oil pan
Fluidyne radiator
99 front timing cover
Innovator's West crank pulley
ARP head studs
POWER ADDERS:
Kenne Bell 2.8H twin screw supercharger
Modular Powerhouse Behemoth inlet
twin 75mm throttle body
Todd Berry custom CAI
8 rib belt set up
Gord's heat exchanger with dual fans
Thump Racing 3 bolt tensioner
Zex 75hp nitrous kit with purge
FUEL:
03 cobra tank
MPH return style fuel system with Aeromotive regulator
80lb injectors
CPR rails
SCT tuner
EXHAUST:
Magnaflow cat back
VRS off road X-pipe
Mac ceramic coated long tube headers
DRIVETRAIN:
03 cobra t-56
26 spline input shaft
MGW shifter
Billet steel flywheel
Spec stage 3+clutch
Dynotech Engineering aluminum driveshaft
aluminum clutch quadrant and firewall adjuster
Eaton Tru trac differential
Moser 31 spline axles
FRPP 3.55 gears
SUSPENSION, WHEELS, and TIRES:
H&R Super Sport springs
Bilstein struts and shocks
MM caster camber plates
Steeda full length subframe connectors
Wild Rides battle boxes
03 cobra front calipers
Brembo crossed drilled rotors
AFS chrome 03 cobra replicas 17x9 17x10.5
New 315/35/17 Nitto NT05R drag radials
HPM megabite JR lower control arms
UPR sherical upper control arm bushings
INTERIOR:
03 cobra front and rear seats
FR500 steering wheel
Autometer Lunar series gauge cluster
Autometer Lunar series fuel pressure and boost gauges
10th anniversary shift knob
MGW silver E-brake handle
Bullitt shifter bezel
Mach 1000 audio system
EXTERIOR:
03 cobra front bumper
03 cobra rocker panels
03 cobra folding side mirrors
Cervini's cobra R hood
Saleen S281 rear spoiler
