Results 1 to 4 of 4
Thread: vacuum line question
    Nov 2008
    ELIZABETH TWP.
    885
    Question vacuum line question
    ok gota question i am running -an line for my booster and puttingt a t valve in on back of carb for a pcv valve... what size -an line should i use 6 or 8-an hose???
    would it really matter or will size determind different vacuum????
    thank you for imput...
    COREY...
    *04 Torch Red Cobra
    471hp/489tq
    Member badstanglx's Avatar
    altoona
    676
    use 6an
    Every time i've ever messed with those lines they have been -6 (3/8")
    Senior Member oldfox's Avatar
    May 2009
    296
    6an 3/8 are you runing Holley or Edelbrock?
    don't know if I would run booster and pvc off the same line or not
  1. Fox body fuel line question
    By White5.0 in forum Fox-SN95
    Last Post: 03-27-2011, 08:15 PM
  2. 5.0 vacuum lines
    By PSPstang in forum Ford Parts
    Last Post: 03-21-2011, 01:00 AM
  3. Line lock question
    By mustang50lx in forum General Tech
    Last Post: 03-10-2009, 08:24 PM
  4. Help: Vacuum Line routing 1995 Mustang
    Last Post: 01-20-2009, 10:56 PM
  5. Brake line question
    By mineralrob in forum The Bar
    Last Post: 04-27-2008, 10:21 PM
