Results 1 to 20 of 30
Thread: Carb question
    ruffsdale
    3,625
    Carb question
    Did anyone change there fox over to carbed? i really want to and dont know what all i need, and if i can just pull through the intank pump or do i gotta do something else? i wanna have it carbed for the first day of track, i got the heads redone,Trick flow cam,clutch, all kinda little stuff but my plugs are burning white its not getting the fuel it needs i think the f.i system on it sucks balls...cause from what i seen it costs so much to make it work with what i have....any idea or help ???
    i would not reccomend to pull through the intank pump, i have done this method and it is really hard on the new pump and can starve the engine of fuel, and you are right about the cost, if you are trying to race on a buggit a carb is deff the way to fly, you would need an intake, carb, fuel pump, air cleaner, and i would reccomend an msd ignition to get rid of the factory controlled electronic ignition, a carb is super easy to tune. call me if you need any help.
    ruffsdale
    3,625
    i got a mallory distrib, with vaccum advance, do i gut the intank pump? what do i use for a pickup? i got a msd blaster coil on the car... i need to find a decent priced carb n intake that would work good, im running a trick flow stage one cam,shaved heads, 1.7 roller rockers..
    you should get a 79-85 mustang tank with the correct pickup, but i have taken out the elec pump and just extended the tube to the bottom of the tank. the mallory dist is ok, but if you have a vlotage spike anywere in the system it will blow out the module, do you have adjustable rockers? if not, because you shaved the heads and are using a aftermarket cam the base circle on the cam may be diff than stock so you will need to check pushrod length and lifter preload before running the car,
    ruffsdale
    3,625
    I had the clearances all checked, im good on that part, ok how much would that pickup cost??... how do i make sure not to get a spike and all that crap??? i'll work on quad's and bikes all day long but this f.i an mustang stuff got me all baffled...sounds like its easier to throw the car away and get a camaro loll j/k
    Belle Vernon
    1,294
    I think it would cost more to switch to a carb. You can get a fuel pump, regulator, MAF, and injectors for about $750 new and I'm sure you wouldn't have any fuel problems, and you wouldn't have to change anything else. Are you running N/A or a power adder. You can also find those parts used all over the place even cheaper. A good carb (demon or holley HP) are gonna cost you $500 - $700 and you still have to get a pump and intake. Either way its gonna cost you $$$.
    Unless you want to get spanked by some mustangs I'd stay away from chevy's LOL.
    '89 Mustang GT
    '04.5 Duramax
    Jones Race Car Trailers
    www.jonesrv.com
    ruffsdale
    3,625
    i got no power adder's i wanna run nitrous, but i really dont like fuel injected, i think carb would make more power easier, a plate nos system would be cheaper too wouldnt it?? a intake shouldnt cost over $200 and $300-$400 for a carb plus whatever the fuel pump and pickup costs
    Belle Vernon
    1,294
    If you prefer carbs, then thats the way for you to go. I don't think there is aything wrong with carbs I just like injection. F.I. also has a NOS plate system that bolts in between the upper and lower intake. My dad runs a carb on his stang and I run injection. Its what ever your more comfortable with. Carbs you change jets, injection you turn up the fuel PSI, take your pick.
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
    ruffsdale
    3,625
    how hard would it be to find a good used maf and stuff?? id buy the pump new
    ruffsdale
    3,625
    im just looking for a easier upgrade, because i wanna build or buy a 347 or 331 this summer, and if the carb is easier to just bolt on and rejet, in stead of having to buy bigger ijectors again and again....i dunno
    Belle Vernon
    1,294
    What year is your car? And whats all the mods you have?
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
    shaler,pa
    1,010
    I have a fresh rebuilt choke horn milled off 750 dbp holley. send me a pm.
    ruffsdale
    3,625
    The car has 3:55 gears, Ram hd clutch,steeda tri-ax,underdrives,cold air intake,no smog or ac or cat's, equal shorties into h-pipe n flowmasters, i got a trick flow stage 1 cam,1.7 roller rockers, shaved heads.....msd blaster coil and cop n rotor,and 9mm ford racing plug wires...
    ruffsdale
    3,625
    opps. and its a 1993 GT, also subframed
    Belle Vernon
    1,294
    When you said that the plug was burning white, was that while spraying it or N/A? I had more done to my car and was fine with the stock injectors, but I had a bigger pump and a fuel regulator to turn up the psi a little. I also didn't spray the car. If you are trying to build the motor mainly for NOS, I'm not the best person to help you, but if you wana go N/A I can help you with any questions.
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
    I agree with the others about staying EFI, but if you are set on converting, I have a Holley street dominator (single plane) intake here cheap. Its never been bolted on, but been around a while ;)
    ruffsdale
    3,625
    my car never had NOS on it, but the plugs are as white as a new hanes tshirt
    HAHA.
    I am with Balaska here. You need more fuel pressure.
    ruffsdale
    3,625
    and how much will it cost me to get more pressure? and how hard to do it ?
    Belle Vernon
    1,294
    If you wanted to stay EFI I would start by putting a new pump in it (255 lph $109), fuel PSI regulator and gauge ($120), and a new fuel filter because there cheap and easy to change. They are all fairly easy to change depending on your experience and tools.
    You said that you had the heads shaved I am guessing that those are the stock heads. Do you know how much they took off and what compression ratio you have now?
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
  1. Blow thru carb?
    By bill412 in forum Fox-SN95
    Last Post: 04-18-2012, 11:55 PM
  2. INTAKE and Carb
    Last Post: 04-19-2011, 08:36 PM
  3. 2V carb question
    By 65 Fastback in forum Fox-SN95
    Last Post: 03-10-2011, 03:38 PM
  4. carb!!
    Last Post: 03-31-2009, 09:57 PM
  5. efi vs carb
    Last Post: 09-17-2008, 03:03 PM
