Results 1 to 3 of 3
Thread: Steeda 1 3/8" front (hollow) sway bar vs. 1 3/8" (solid) sway bar
    Question for my fellow Stangbangers. Doing a four wheel disc SN 95 Cobra brake swap on my 86. Figured I would change the sway bars too. I have Suspension Techniques sway bars. The front is 1 3/8" solid sway bar. What benefit would it be for me to change to a Steeda 1 3/8" sway bar that is hollow (besides overall weight distribution).
    I have a 1995 Explorer that came with a large (hollow) front sway bar. I put on Explorer Express sway bars which were solid and it tightened up the front end.
    Which goes back to my original question, what benefits besides weight distribution would I get with a Steeda hollow sway bar?
    No one has ever used a Steeda 1 3/8" hollow bar?
    Brookline
    2,897
    How much weight difference is there? I would imagine a hollow bar will lighten up a little bit, but also not be as rigid as a solid bar. Also, it's gotta be somewhere like, 10-15 lbs difference? I would think that's a marginal difference to really notice much?
  1. Fox front sway bar larger than 1"
    By Floyd in forum Ford Parts
    Last Post: 09-09-2014, 12:08 PM
  2. front sway bar needed!
    By teal sn95 in forum Ford Parts
    Last Post: 03-27-2013, 09:59 PM
  3. WTB Front sway bar.
    By 01cobra in forum Ford Parts
    Last Post: 09-24-2008, 09:25 PM
  4. Stock front sway bar 5.0L
    Last Post: 03-18-2008, 12:20 PM
  5. Front Sway Bar
    By coralcoupe1993 in forum General Tech
    Last Post: 10-25-2007, 01:09 AM
