Roger....put the passenger kick panel and unbolt the computer. Youll see a black plastic plug, if not youll see a chip sticking out.....if it has a chip its been tuned.
XXX RWHP
XXX RWTQ
Coo thanks Mike.. Looks like I will be ordering a FPR and a code reader tomorrow..
wvstreets.CO
Sweet talk Kuneff and we might be able to borrow his for a day for so.
XXX RWHP
XXX RWTQ
Fox and SN95 regulators are different part numbers... :(
wvstreets.CO
Idle like shit and sputter under load?
wvstreets.CO
113 for a regulator.. I hope its fixes but I am not confident my money spending is over LOL
wvstreets.CO
Sounds like it's got more than one problem. Since you found fuel in the vac line to it, replacing the FPR is a good start.
Here are a couple FPR I found on summit anyone use these or can recommend one..
http://www.summitracing.com/parts/PFS-10681/
and
http://www.summitracing.com/parts/AEI-13102/
wvstreets.CO
Well I knew ordering the FPR sat or sunday would make no difference cause of shipping so I held out and did some more testing.
TFI tested and passed 5 times.
Replaced fuel filter
used a whole can of carb cleaner shooting vac lines and intake manifold (nothing)
Check the timing again still on 12deg
The car still stumbles during idle and hesitates at WOT.
Fuel pressure holding at 38 idle swings to 45 WOT then drops to 30ish and recovers to 38 back to idle.
Voltage on the TPS is .98 idle and 1.64 WOT I think that is out of range for WOT but dont know how much of an effect that will have.
I am still leaning on FPR is the issue because I well dont know what else to think. Bad injectors, Failing Fuel pump, TPS, MAF all suspects still..
Monday I am ordering a Code Reader and FPR.. unless someone comes up with something else for me to check.
wvstreets.CO
you hsould be around .95-1 volt idle and 4.5-5 volts WOT.
fix the TPS
My bad it 4.65 WOT.. long day..
wvstreets.CO
Although you should not smell fuel on the FPR line as you did, these are likely typical readings for fuel pressure. Everything is referenced to manifold vacuum, so you have a base with vacuum (38), then the vacuum goes down with WOT so the rpessure goes up (45), then the vacuum recovers with less load (30ish), then back to idle. Again it may be leaking, but it looks to still be roughly working.
You need a code scanner sooner than later to see what the EEC thinks is wrong. Not saying that will point you to a bad component, but it will tell you what the EEC doesent like ;) Is the ECT hooked up on this thing (Engine Coolant Temperature)?
Alright Code reader came today and I walked my happy ass right out there in the rain and pulled codes..
172 HEGO Ho2s Fault/Lean
176 HRGO Ho2s Fault/Always Lean
212 Loss of ignition diagnostic monitor signal/Spout circuit grounded
OK so I recently set the timing that required me to pull the spout connector so I can for the most part dismiss 212.
172 This is interesting because when I got the car it was running really rich in the left bank but the O2 now reports a lean condition. (may have been why the Fuel Pressure was turn up to 50psi when I got the car) Now at 39 psi
176 appears to be more of the same just stating that the car is running ALWAYS lean on the left bank. The self Test reported nothing these codes were in system memory. The car sat for weeks with no battery so I assume any codes prior to my owning the car were long gone but I might clear the codes and see what is generated from its current setup.
The bad regulator theory becomes even more relevant as it only seems logical that the left bank would be the first suffer from a bad FPR. Vac leak but I cant find one.
You think I am on the right track?
wvstreets.CO
Did you pull the lower intake as well?
