Results 1 to 16 of 16
Thread: Tire question
    fairmont,WV
    1,352
    Tire question
    I have came across a super cheap set of 16" wheels that I want to use for drag radials. When I say cheap I mean free. I have 2 options....16x8 and 16x9. Which wheel would be best for some drag radial? I would love to try some ET streets or maybe even ET radials....what are your guys suggestions?
    XXX RWHP
    XXX RWTQ
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    Wider is better. I would go with the 9".
    2014 M235i (wife's)
    1964 Ford F-100
    fairmont,WV
    1,352
    Ok Ill pick up the 16x9's....what size tire? I am considering some ET radials but I have no clue how to size those.
    XXX RWHP
    XXX RWTQ
    Mars, PA
    1,696
    If you want to keep your stock 26" diameter and run a MT radial, the only size available is a 255/50/16 which would work best on the 16x8. Radial tire choices become very limited with 16's.
    Dennis
    2006 GTO
    Gone but not forgotten
    2015 SHO
    Mostly stock
    2014 Cruze
    Living the MPG life
    fairmont,WV
    1,352
    i have a set of each so goin w/ 8's wont be a problem. I would like some wrinkle wall dot tires to play around at the FLD's....so Im willing to listen to suggestions.
    XXX RWHP
    XXX RWTQ
    Mars, PA
    1,696
    I would look into the MT ET streets or the Hoosier Quick Time Pros. Both of those would work well
    Dennis
    2006 GTO
    2015 SHO
    Mostly stock
    2014 Cruze
    Living the MPG life
    fairmont,WV
    1,352
    Will do....can you help me w/ the sizing....Im completely new to sizing tires like this.
    XXX RWHP
    XXX RWTQ
    never stock biminiLX's Avatar
    Beaver
    2,406
    Do you have a stick? how much power? you want them just for the strip or FLDs or any street use?
    Mars, PA
    1,696
    If you go with a bias ply, a 26x10.50x16 should fit either of those wheels pretty well
    Dennis
    2006 GTO
    2015 SHO
    Mostly stock
    2014 Cruze
    Living the MPG life
    Beaver
    2,406
    Yeah those should work well.
    I'd personally go with the 9" wheels if its the same price and will fit.
    Bias-ply MT ET Street, Hoosier QT Pro probably the best bet but not too familar with the 16" options.
    fairmont,WV
    1,352
    I have a 5spd and its for FLD's and maybe the strip...I wont be driving these on the street. Right now Im only at 400 rwhp.
    XXX RWHP
    XXX RWTQ
    Beaver
    2,406
    Cool, original ET streets or Hoosier QTPs is what I'd use.
    As much as I personally like Hoosier tires (both slicks and Quick Time Pro's), I would really shy away from them for a FLD type application. They can be rather sensitive to burn out procedure and have some quirks. Those quirks can be managed quite well on a drag strip and hook like crazy but I suspect the ET Streets are more forgiving (but havent used anything from MT in several years).
    Beaver
    2,406
    Good point, I'd definitely listen to your experience there :)
    LOL, well I might be wrong on the ET Streets, I havent had a set in I think five or six years (although I will likely try ET Drags when my hoosier slicks are worn out).
    Like I said, nothing at all wrong with Hoosier tires, it's just that they like things a certain way and I hate to see someone think it's the tire. Add in a stick shift car and they are even more quirky ... Ed and I both went through the learning process on them for sure.
    You remember my buddy Dale (TR7), he was struggling with QTP's at Columbus a couple of years ago saying all they did was spin ... I went through the process with him, next pass he hit it right on, and almost smacked his face off the steering wheel on the next hit because it hooked so hard and bogged :D (not enough RPM ).
    Sometime this year we might see if the QTP's work at a FLD type race. Wanting to go to Sunset with my junk and give it a go myself.
    fairmont,WV
    1,352
    Thanks for the info guys. Sounds like I should go w/ some MT's
    XXX RWHP
    XXX RWTQ
  1. Yet another tire/wheel fitment question.
    By phillysrt4 in forum S197
    Last Post: 06-18-2014, 05:20 PM
  2. Tire sizing question..
    By pRojekt02GT in forum The Bar
    Last Post: 04-27-2009, 10:23 AM
  3. Tire Size Question
    By street591 in forum General Tech
    Last Post: 03-12-2009, 10:32 PM
  4. tire guy question?
    By 85stang in forum General Tech
    Last Post: 08-18-2008, 11:48 PM
  5. Truck Tire question
    Last Post: 08-10-2008, 12:44 PM
