Results 1 to 5 of 5
Thread: injectors and maf
    cruisin for a bruisin geps91stang's Avatar
    Aug 2010
    connellsville
    160
    injectors and maf
    i got a quick question for you guys when adding bigger injectors #24lb and matching maf does the computer need to calibrated ( gt 91 )
    Member torqueboxer's Avatar
    white oak, pa
    638
    No..
    Brighton Township
    1,665
    Injectors are not changing the airflow characteristics across the MAF.
    Only the injector tables need changed.
    2019 Tesla Model 3 Performance
    You're in a GM/HPT state of mind, SK. LOL
    An old school Ford EFI trick that guys have been doing for years is to buy a MAF that's been tweaked to provide fueling that matches the injector size they're upgrading too.
    In this case, no, you do not need to change anything in the PCM. The replacement matching MAF will provide correct fueling for your new injectors.
    So, short answer to the OP: "no"
    Aug 2010
    connellsville
    160
    ok thanks guys
  1. maf/injectors questions
    Last Post: 07-31-2012, 05:21 PM
  2. 04 Cobra stock injectors and MAF
    By 724COBRA in forum Ford Vehicles
    Last Post: 05-10-2011, 05:30 PM
  3. 30lb injectors and MAF
    By Balaska347 in forum Ford Vehicles
    Last Post: 01-24-2010, 11:55 PM
  4. For Sale: MAF + 24 lb injectors
    By 95DropTop in forum Ford Vehicles
    Last Post: 07-31-2009, 09:53 PM
  5. WTB MAF for 42's, and injectors
    By delldoe in forum Ford Parts
    Last Post: 05-30-2008, 09:41 AM
