Results 1 to 5 of 5
Thread: Garage clean out parts got to go
    ILLBEATU fastfox91's Avatar
    huntingdon,pa
    830
    1. vortech ys trim kit with race m bearings. headunit is polished, comes with a 8 rib set up, blower pulley is a 3.33 and the crank pulley is a 6.87. its a passenger side mount kit with a few modifications to fit a 9.5 deck motor but will still bolt up to a 8.2 deck motor. there is roughly 8,xxx miles on this head unit. 2000.00 plus shipping
    2. Complete 347 shortblock (std bore 342) chp street killer kit, 10.5-10.8 to 1 depending on head choice, cut for inline and canted valve heads, lunati camshaft, lifters, dog bones and hold down, timing cover, power bond 28oz balancer. just add you heads and intake and go. 1300.00 prefer pick up.
    3. vortech t trim that needs a impeller, a plastic ring on a bypass came loose and had its way with the impeller, ive had this for a while with intentions on getting it fixed and just never got around to it. 800.00
    4. vortech mondo bypass valve satin finish 200.00 plus shipping
    5. holley 850 4150 dp carb this carb is used and has had some work done on the base plate ears but is fixed. has been sitting and have no use for it anymore 100.00 plus shipping thanks
    6. cartech fuel pick up with -8 feed and -6 return 80.00
    7. -10 summit fuel filter part# SUM-230115 40.00
    8. asp smog delete pulley 30.00
    9. pa performance sfi 28oz 157tooth flex plate for sb ford 75.00
    10. stock tko600-500 shifter 30.00
    11. sumped gas tank for foxbody 100.00
    Senior Member fox fan's Avatar
    Jan 2010
    Washington Pa
    235
    pm sent
    Mar 2009
    796
    Does the short block have flat top pistons?
    huntingdon,pa
    830
    yes they are flat tops with both inline and canted valve reliefs
    huntingdon,pa
    830
    carb is sold
    all pms have been returned
  1. Replies: 22
    Last Post: 06-23-2015, 04:39 PM
  2. Garage Clean Out
    By Maxpowers in forum Ford Vehicles
    Last Post: 10-08-2013, 02:23 PM
  3. Garage clean out - 5.0 parts
    By 94Cobra in forum Ford Vehicles
    Last Post: 04-22-2010, 01:18 PM
  4. Garage clean out
    By 94svtcobra in forum Ford Vehicles
    Last Post: 12-26-2009, 10:28 PM
  5. FS: Garage Clean Out
    Last Post: 07-19-2009, 05:53 PM
