i was wondering whats the best paint to use on my intake i know the plenum's on the ho engines get really hot i want to use a paint thats not going to flake right off from the heat also looking for paint for heads and block thanks
I think you will mostly hear powder coating these days, especially if you really want it to last. I've always had good luck with VHT paints for high heat stuff. They have two levels, one for heat, another for higher heat. Follow the directions on either ;)
+2 on the powder coating it's just reasonably affordable and the tuff, and easy to clean finish without worrying about rubbing paint off . It's also going to last longer as well. Collins on here would probably hook you up. I'm having him do a set of valve covers for me soon.
Life is a Journey, enjoy each moment. Don't take life to seriously, none of us make it out alive anyway.
Toys:
1993 Cobra #1118 Black/Black Cloth 45k
2013 Ford F-150 FX4 4x4 C.C.
1997 SeaRay 190RS MERC. S.S. prop./Hydrafoil
2005 Honda Aquatrax R-12x & F-12x Turbo's
2010 Kawasaki Z1000
2005 Ford Mustang GT/Roush Stage1 Package **FOR SALE ASAP**
Yep. Another vote for powdercoating here.
2015 GTPP
what's the recommended temperature range for powder coating? How hot can you go?
Powdercoat. Here is a pic of mine done black.
http://www.steelcitystangs.com/forum...ad.php?t=20702
Powders cure at 400 degrees. Standard powders once cured are more than sufficient for use on non exhaust engine parts. For exhaust parts you would need high temp powder good to 1200 degrees typically or a ceramic coating. For the plenum standard powder would do the trick.
Hope this helps.
Randy
Thanks for the response...do you guys do any high temp powder for exhaust components?
I had a painted intake for years and never had any problems with flaking and such. I will say though that poweder coating is a better option. I coat all of my own parts that fit into my tiny oven, and I have used the high heat powder coating as mentioned above on a set of shorty headers with decent results. The powder never flaked though it turned more satin in appearance after a few heat cycles than it looked when I first did it.
What color are you looking to do the plenum in?
The block and heads I would just use a high temp paint on.
Randy
i looking to paint it black or silver i'm leaning more toward silver
