Results 1 to 7 of 7
Thread: Lookin 4 advice on puttin on aftermarket steering wheel
    Junior Member Fantly45's Avatar
    Mar 2011
    West Mifflin
    7
    I went to put on a aftermarket steering wheel yesterday on my mustang and had a puller and everything. It has cruise control that does not work so I was gonna just eliminate and also tilt now I have a stock ford wheel and couldnt get the thing pulled off. Has anyone on here replaced thier stock 88 wheel for aftermarket one. If so did you have to use any special adapters or wheel.
    Petersburg,PA. 16669
    816
    they can be a real pain to get off sometimes
    could try a lil heat once you have the puller on there and tightened up
    88 GT...and some boost
    Member silvernotch's Avatar
    Bethel Park
    664
    only one bolt under the horn pad.
    Mar 2011
    West Mifflin
    7
    Ya I had the bolt off from under the horn pad. It really didnt have anywhere for me to hook the puller to and get a good pull. The pic of the new install kit shows a treaded stem from the column and a nut that holds the wheel on mine is a bolt that treads into the center of the stem and the puller seemed like it wanted to tread into it. I thought that it should just act like a pivot point to push off not tread into. Does ford have there own style puller?
    Mt Pleasant, PA
    4,905
    I use one of these style pullers,
    http://www.jcwhitney.com/steering-wh...FYFM4Aodk0t-DQ
    There are 2 small bolt holes near the center that you use to anchor the puller.
    Mar 2011
    West Mifflin
    7
    Ok Ill have to get one of them I was thing about those treaded holes and away to use them thanks for the help
    Mt Pleasant, PA
    4,905
    Quote Originally Posted by Fantly45 View Post
  1. Need Wheel touch up advice
    By Darren in forum General Tech
    Last Post: 04-21-2013, 01:43 AM
  2. have an FR500 steering wheel?
    By jaa55 in forum The Bar
    Last Post: 06-08-2010, 02:46 PM
  3. 90-93 leather steering wheel
    By venom in forum Ford Parts
    Last Post: 09-10-2009, 06:33 PM
  4. 96 GT . . lookin for some advice
    By cwh19 in forum Welcome New Members
    Last Post: 06-18-2009, 11:55 AM
  5. Replies: 22
    Last Post: 06-08-2009, 10:19 PM
