Results 1 to 4 of 4
Thread: 88 mustang voltage question?
    Junior Member Fantly45's Avatar
    Mar 2011
    West Mifflin
    7
    I have underdrive pulley system and I know that its going to affect the voltage but when I am driving at night and stop at a red light with the turn signal on it really pulls the volts down. I wanted to but an electric fan it and thought I would need more consistance voltage for everything to run right. So yesterday I put a 100 amp alternator in the car it still seems to be bout the same issue. Do i need a smaller pulley to make it turn faster or should I look in to a better battery. there is a duralast batt in it now. Any tips or info?
    Did you check voltage across the battery with the engine running? Did you do the 3G upgrade or just a 100 amp fox alternator? You may need a smalley alternator pulley to spin it faster. Especially at idle. I had underdrives on mine long ago. Had the same issue. I tossed them in the garbage can where they belong and never looked back. In the real world, you gain nothing from them except a fancy set of pulleys.
    Nov 2008
    ELIZABETH TWP.
    885
    u can get a smaller pulley for it from march performance, i went through the same thing or just throw ur underdrives over the hill...they really dont do that much for u anyways....
    COREY...
    *04 Torch Red Cobra
    471hp/489tq
    LowHill
    2,679
    I sold my underdrives, they do nothing, car ran the same with stock ones and my turnsignals work great
  1. High Voltage issue on constant... car off. 90 fox
    By OctaneGraphix in forum Fox-SN95
    Last Post: 01-22-2014, 08:05 PM
  2. Maybe mustang owner - question #2
    By Warrior1670 in forum Welcome New Members
    Last Post: 10-26-2010, 07:45 PM
  3. MAF voltage low after blower install
    By 95DropTop in forum Fox-SN95
    Last Post: 04-14-2009, 04:53 PM
  4. Suggestions on selling a voltage regulator?
    By fordandmopar21 in forum The Bar
    Last Post: 09-02-2008, 11:41 PM
  5. Mass Air Voltage Too High
    By mhuckabee in forum Fox-SN95
    Last Post: 06-30-2008, 05:00 PM
