Results 1 to 1 of 1
Thread: FS: Crane Power Master 2040 Cam, Lifters, Timing Chain. New
    Mt Pleasant, PA
    4,905
    I have a new Crane Power Master 2040 roller cam, roller lifters, and double roller timing chain. Everything is new but was installed, NEVER RUN. I bought the car in mid project and it is way too nice for all the mods so im returning it to stock. 300.00
    ( The lower timing gear is missing in the photos but is there, just forgot to put it in the picture)
    This cam is supposed to be identical to the Ford Racing E cam. Here are the specs.
    Part Number: 444231 Grind Number: POWERMAX 2040 (FORMERLY COMPUCAM 2040)
    Engine Identification:
    Start Yr. End Yr. Make Cyl Description
    1985 Up FORD-MERCURY 8 GOOD MID-RANGE AND STRONG TOP-END POWER, REQUIRES MODIFIED MASS AIRFLOW, AFTERMARKET INTAKE, PERF. CYLINDER HEADS AND HEADERS, MUST USE 5-SPD AND 3.55 OR NUMERICALLY HIGHER REAR GEARS. REQUIRES CRANE SPRINGS AND RETAINERS. (50 STATE LEGAL 85-93, C.A.R.B. E.O. D-225-46) BASIC RPM 2400-6000
    Engine Size Configuration
    302 C.I. V
    Valve Setting: Intake .000 Exhaust .000 HOT
    Lift: Intake @Cam 311 @Valve 498 All Lifts are based
    on zero lash and theoretical rocker arm ratios.
    Exhaust @ Cam 311 @Valve 498
    Rocker Arm Ratio 1.60
    Cam Timing: TAPPET @.004
    Lift: Opens Closes ADV Duration
    Intake 28 BTDC 74 ABDC 282 °
    Exhaust 68 BBDC 34 ATDC 282 °
    Spring Requirements: Triple Dual Outer Inner
    Part Number 99838
    Loads Closed 110 LBS @ 1.688 or 1 11/16
    Open 320 LBS @ 1.208
    Recommended RPM range with matching components
    Minimum RPM 2500
    Maximum RPM 6000
    Valve Float 6500
    Cam Timing: TAPPET @.050
    Lift: Opens Closes Max Lift Duration
    Intake 0 BTDC 40 ABDC 110 220 °
    Exhaust 40 BBDC 0 ATDC 110 220 °
    Remarks:
    FIRING ORDER: 1-3-7-2-6-5-4-8
  1. 30k cadillac timing chain shot
    By 92306gt in forum The Bar
    Last Post: 11-04-2011, 06:55 PM
  2. Timing Chain And Gears Help
    By 955.0 in forum Fox-SN95
    Last Post: 02-02-2010, 11:54 PM
  3. WTB timing chain cover 5.0
    By jaa55 in forum Ford Parts
    Last Post: 04-24-2008, 12:44 AM
  4. Crane Link Bar Hydraulic Lifters
    By 04yellowcobra in forum Ford Vehicles
    Last Post: 01-20-2008, 03:28 PM
  5. 5.0 timing chain
    By eddmann55 in forum Fox-SN95
    Last Post: 12-28-2007, 10:05 AM
